Question about Lexmark C750 Laser Printer
,my copies are almost to light to read, ive only had the printer for a couple of weeks the printer is a lexmark c750 laser
  • 34 Answers
How many pages do you think you've printed?
If this was a brand new printer it might already need new toner. The "starter" toner they give you with a new printer usually doesn't last long.
Posted on Jul 03, 2009
171 motor error on C750
make sure the gears is good other change the motor
Sep 09, 2011 | Lexmark C750 Laser Printer
I have several Lexmark C750 and they all have vertical streaks on the right hand side. I have trying to find some type of wear and tear, so I know which parts to order. I examined the color cartridges,...
You may have to clean the ink jets.. go into the software where it manages the print heads. Run it through clean print heads or jets program several times. Then run the realign program and see if that helps.
Oct 04, 2017 | Lexmark C750 Laser Printer
The Lexmark C750 leaves about a 1 inch band of all the colors upon startup. The initial color calibration is leaving the band. Konicas can produce the same problem. The transfer belt is new. The problem...
The problem could be caused by an alignment problem. Please try to do an alignment on your printhead.
http://bitly.com/oXAQuG
If you need further assistance please contact Lexmark Technical Support.
Aug 09, 2011 | Lexmark C750 Laser Printer
Will the toner out of a C760 work in a C782
Color Laser Toner Cartridge is compatible with Lexmark X762E, X762, so it will not work in C782
Lucas
Jul 07, 2011 | Lexmark C750, C752, C760, C762, C770,...
Colors don't line up
kindly replace the inkcartdreg and see
Dec 16, 2009 | Lexmark C750 Laser Printer
Where is the paper jam when the panel of our Lexmark C750 says "200 paper jam"
Primary: Paper is jammed at the printer input sensor. Open the printer left door to access the paper jam. If sheets have been accumulated to be stapled or offset when the jam occurred, the printer alternately flashes the primary and secondary messages to indicate that all accumulated sheets not be removed during the jam clearing procedure.
Secondary: When this message is displayed, do not remove accumulated sheets during the jam clearing procedure as the printer will not reprint the removed sheets. Also, if the accumulated sheets are removed, the portion of the job printed after the jam will not be stapled.
Nov 03, 2009 | Lexmark C750 Laser Printer
900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
May 24, 2009 | Lexmark C750n Laser Printer
Intermitantly streaking copies
Sounds like the wiper blade in one of your cartridges has failed. Try swapping cartridges and see if this helps. The problem could be with only one of the cartridges, so try changing one at a time to find which one is causing the problem
Jan 23, 2009 | Lexmark C750 Laser Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Lexmark C750
Theres a lexmark c750 service manual on a cd available on e-bay right now as I type It says it will end April 21. GO FOR IT!!! Good luck
Apr 18, 2006 | Lexmark C750dn Printer
Lexmark C750 Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
