Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
I have a 120GB Western Digital Passport external hard drive and it will not open up on my pc. the WD passport will turn ''on'' and light up and the pc will detect that a usb is plugged in but it will not appear as one of the hard drives or ''local disk'' on ''MY COMPUTER''. It will begin to make a humming and spinning sound on and off. i tried using another usb cable plug and still nothing. i tried using another pc and still nothing. I can't open up my WD passport to get to important files. Please help me.
  • 23 Answers
Sounds like your passport is not working anymore. The fact that it wont work on another computer is a solid sign that something has failed in the device itself. Its possible that both of your comptuers have USB 1.1 but I would think this is unlikely.
I would plug it in to one of the comptuers, then go into your administrator tools then open your computer management tool(start>control panel> administrator tools> computer management). This will allow you to see if windows is detecting the drive at all. Sometimes if the file directory is corrupt, or the hard drive is even partially damaged, then it will not show up under "my computer" but it might show up under your computer management tool. If you see it on there, then there is probably something wrong with the hard drive that is not allowing the computer to recognize the device, or at least install it properly. If you dont have any crucial data, you can just simply reformat the drive and it might start to work after that. If you do, then you might have to take the thing apart and transfer the data by using the hard drive like it was just another drive on the computer.
If your computer does not detect the drive at all, not even on comptuer management, then I suspect the drive, or at least the adapter part of it is not working, in which case, you will need to remove the drive from the casing and use it as if it was another internal drive, you might be able to reformat it, then put it back in its casing, and hope that it works after that, but I have never taken a WD passport apart before, so I would recommend doing a google search to see if anyone else has done this before.
FYI, when I bought my WD passport, I bought a replacement plan with staples beucase I knew that with all the traveling I did, I would eventually break it. I have dropped it about 3-4 times only after about 4 months, the thing still works without any problems, but that just goes to show how well WD builds their drives, however, I am sure that if I wasn't so lucky, that I would be calling them up right now asking for a new one.
Posted on Jul 03, 2009
Tip
Troubleshooting WD Passport 320 GB External USB 2.0 Hard Drives
If you plug your Western Digital Passport External USB 2.0 hard drive to a USB socket in your computer system, & the hard drive's light is on but there is no spinning sound, then you might be experiencing a defective interface circuitry.
These devices have a USB-to-SATA interface inside their enclosure. If you can find another enclosure with a similar interface (or buy a new enclosure), disassemble your hard disk enclosure, get the hard drive out & attach it to the interface in the other enclosure & see if it works.
Another possibility is that the interface could be fine, but the hard drive itself died. To test this possibility, try attaching the hard drive itself (after getting it out of its enclosure) directly to a PC. Since the hard drive is a SATA drive, you will be able to do this easily.
on Dec 01, 2009 | Western Digital Passport 320GB External...
My WD my passport not working
maybe the cable plug of the WD my passport is broken
Apr 18, 2013 | Western Digital My Passport Essential...
I wanted to back up the files on my WD passport. Apparently I cannot move the majority of my files and there are some .exe and .inf files on my wd that are locked and not removable. my guess is that it...
Hi and welcome khaksh ,
Connect your passport to your lap .
Let your antivirus full scan the content of it .
Complete the scan with MalwareBytes , a powerfull malware killer :
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
To completely finish the job , have the content of your lap fully scanned by both applications .
When you are shure both pc and passport are virus free , try accessing locked files as administrator .
I hope this will help you .
Best regards ,
Feb 12, 2011 | Western Digital Passport 120GB External...
How to remove the wd smartware software on the passport essential
Open "Windows Explorer".
Select the 'WD SmartWare' folder.
Press DELETE to delete the folder, and its contents.
May 18, 2010 | Western Digital Passport 320GB External...
My usb ports are limited to 500mA each one and the WD external HD needs at least 1000mA. How can I solve that?
You might need to install a new USB card, one with 1000 mA, to provide the power necesary for your WD external drive. Check the WD manual to see whether there is a way to use two USB ports when jumpering them to see if you can provide the power yourself.
Also check the WD web site.
Jun 26, 2009 | Western Digital Passport 120GB External...
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Jul 30, 2008 | Western Digital Caviar WD2500BB 250 GB...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
864 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
