Question about Whirlpool Washing Machines
How do you tighten up a washing machine tub whirlpool is my brand
jsrock516
  • 5911 Answers
SOURCE: need to tighten loose agitator on whirlpool
You need to pop the cap off the center post of the agitator, followed by removing the plastic cap and o-ring inside. The agititator bolt is located underneath. Tighten with (I believe) a 9/16 socket with ratchet. Tighten until snug. Do not overtighten as this can restrict agitator motion and may crack it.
Now, if you talking about the upper portion (auger) of the agitator slipping, you will need to replace the agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The dogs are small plastic teeth that are located under the center post cap used to grip the auger as it turns. They do wear out periodically and require replacement. If you go to appliancepartspros.com and type in you model number you can view them as item number 10 under the "Agitator, Basket & Tub" section. You can use the part number I provided in the link, or use the Whirpool part number on the website. Both numbers cross reference to the same part. A very inexpensive fix...
If you still need assistance, please let me know. I hope you find this information helpful.
Posted on May 14, 2009
ghappliances
  • 126 Answers
SOURCE: Whirlpool washing machine, tub is disconnected
IT CAN BE FIXED AND ITS BEST YOU GET THE TECHNICIAN TO REPAIR IT AS RESETTING THE DRUM IS A DELICATE TASK IF YOU DONT DO IT CORRECTLY THE PROBLEM WONT GO AWAY.GOODLUCK.MOHAMED
Posted on Sep 16, 2008
  • 8 Answers
SOURCE: Whirlpool Washing Machine won't spin
Sounds like motor controller or motor either way it's not cheap...Sorry
Posted on Mar 13, 2009
VtToolMan
  • 704 Answers
SOURCE: wash tub overfilling on whirlpool washing machine
Hello GPMill, Based on you problem analysis, you have a faulty water level switch and that needs to be replaced to get your washer to only fill to the level selected on the control panel.
The replacement part is #3366846 and it usually is priced at aournd $30 whether you get it online or at your local appliance dealer.
Here's the line drawing/diagram that shows the part and where it's located. This is a relatively easy repair for a homeowner to do themselves, provided you take your time and unplug the washer from the electric outlet an turn off the incoming water supply lines.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GSQ9340EQ0&productCategoryId=0153200&brandId=1198&modelName=DIRECT-DRIVE-WASHERS&diagramPageId=00002&componentDescription=CONTROLS%20AND%20REAR%20PANEL&documentId=O2027171&blt=06
The fill valve is Item #12 on the drawing and is connected to the top control panel. To get to the control you need to remove the screws at the top and back of the backsplash control panel and also pull the front knob off the stem of the valve.
Once you've done that, you'll be able to get at the screws that hold the valve onto the washer's control panel. Simply unplug the wiring harness plug that goes to the valve and replace it with the new one, reinstalling the wiring harness plug and mounting screws and the knob.
It should take you around 30-45 minutes, but allow for double that time just to be certain. I also suggest that if you're a first timer DIY'er, take some pictures (use your digital camera or phone) of the valve and how it's installed before you begin the removal process to provide you some pictures to refer back to, in case you need them.
If your water level valve has a small hose attached to it (some version did), make sure that the hose is clear of any obstructions too, as this can affect the valve from working properly.
By doing these minor repairs, you can easily extend the working life of your appliance for many years before you need to replace them.
I hope you find this Very Helpful and best regards!
Posted on Nov 24, 2009
  • 151 Answers
SOURCE: I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Posted on Dec 24, 2009
Wash tub removal?
There is corrosion on your drive shaft due to Liquid Detergent use. You will have to push the tub back down and yank it up several times to remove it... sort of a slide-hammer effect. Whirlpool Washing Machine Tub Seal and Bearing Kit W10435302 Whirlpool Washing Machine Bearing Driver W10447783 When the unit is fixed...SWITCH TO POWDERED DETERGENT!
Jul 12, 2016 | Whirlpool Washing Machines
Whirlpool washer tub will not hold water it goes right through then drains. This is my 2nd brand new one
your drain is not installed properly . pipe has to be at least as high as the side of the machine .
May 14, 2016 | Whirlpool Washing Machines
Spin no squeeze
Drain it, unhook it and lay it down, check underneath for broken springs on the drum to the frame
Sep 25, 2012 | Whirlpool Washing Machines
Mildew smell inside wash tub of my Whirlpool Cabrio
Apparently it's a common fault (among others) with this brand/model of washer; as Whirlpool has dedicated a page to it.
How to clean the interior of your washer to remove odors
Dec 19, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
We have an inglis washing machine we bought may of 2009 and now it will not spin. If you turn the tub it will and also if the load is very light it will spin. Can you help?
inglis is a whirlpool brand, and your within their 1 year coverage, you might contact them and see if they will send out a tech. doesnt solve your problem, but it sounds like a motor problem to me.
Mar 24, 2010 | Whirlpool Inglis IP4400 Washer
Ultimate Care 2 is leaking water and not from hoses. Only in use.Is there a easy fix for this?
Check the washer tub gasket seal.. Normally located under the base of the tub. May just need to tighten any bolts that are loose around the gasket if there is one.
Mar 12, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
The inner tup on my whirlpool washer is loose.
look at this part at www.repairclinic.com/SSPartDetail.aspx?=t-LSR5132PQ-%3d%3di541811&PartID=541811 This is a washer's lint catcher and when clogged will prevent complete water removal. As far as the unbalanced check the levelness of your machine in both directions.
Mar 10, 2009 | Whirlpool LSR5132PQ Top Load Washer
Loose agitator
Remove the center dispenser. Under the dispenser is a plastic cap with a pull handle on it. Pull the cap straight up and you will find a mounting bolt underneath. Using a socket and ratchet, tighten the bolt snug. DO NOT overtighten as this may cause damage to the agitator. If you go to searspartsdirect.com and type in your model number, there is an excellent exploded view diagram of the agitator components under the "Agitator, Basket and Tub" heading. If you still require assistance, please let me know. I hope you find this information helpful.
Sep 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
1,948 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
