Question about Thermador SC302T Electric Double Oven
F7 Problem on Thermador sc301
I tried resetting the oven for 3-5 min. due to error F7 and held OFF button for 10 seconds, but still not resetting. Please advise what to do next. I can't get any of the buttons to beep. Just the beeping F7 error. I had my capacitors replaced by having it shipped off to CGI.
SOURCE: I have a Thermador SC301 wall oven and the display
I have just repaired two SC301 ovens myself, but it is alot of work. You can get the oven's LED lights reconditioned at a company called CGI industries. Look them up on the web and click on the link for thermador. Removing the led panel and oven relay board is an involved job, but easier if you do it the correct way. First, turn off the power to the oven. Then pull the oven out of the wall socket about 1 quarter of the way. Remove the top cover of the oven with a phillips screw driver. This reveals the oven relay board. Take a digital picture of the board to remember the wire positions, or alternatively write them down. You also need to remove the touch panel (two screws underneath) and gain access to the LED. Remove the LED panel and wires. ship both to CGI (boards only) and you will have them back in less than a week. Costs about $170 before shipping. Reinstall and turn power on. All is good.
Posted on May 03, 2010
Master_Tech
  • 770 Answers
SOURCE: f7 error
F7= function key is stuck or shorted >> you can turn the breaker off to the unit then back on if it come back up it will have to be replaced
Posted on Jan 27, 2008
thaurfen
  • 623 Answers
SOURCE: F7 trouble code
One of the most common problems with GE electric built in ovens is the error code “F7′ shown on the display. I’ve seen it many times before and today I had a service call for the same problem again. The error code “F7” will be displayed along with a beeping sound if the ERC (Electronic Range Control) or “clock” senses one or more buttons on the control panel stuck. It could be displayed in any mode: “cook”, “clean” or even more often in the “time of the day” mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the “search” button and in the new window type the word ”control panel” in the “search by keyword” box and click the “search” button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business
Posted on Nov 10, 2008
aborcass
  • 2651 Answers
SOURCE: Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Posted on Mar 14, 2009
SOURCE: F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Posted on Feb 18, 2011
Thermador sc301
Read the info FROM Rick Ead at the bottom of this reply.
Apr 19, 2014 | Ovens
The lower screen on my oven is showing CAL. i can not push any buttons. What should i do.
Try unpluging the oven for 10 min's then plug it back in to reset get back to me , if you still arent working but i will need the brand , model, serial number
Sep 08, 2011 | Thermador C301U Electric Single Oven
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
I have a Thermador SC301 wall oven and the display has faded out. Thermador says I need to replace the whole control unit ($500 for the part!) Any cheaper fix?
Feb 08, 2010 | Thermador Ovens
F7 shows on display and display getting dimmer over months
Dim display is TOTALLY independent of F7 error.
The display will dim as the display board capacitors wear out - due to the heat. Replace the capacitors on the display board (see my other posts) and your be able to see the F7 error code as bright as can be!
Jul 16, 2009 | Thermador SC302T Electric Double Oven
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Error F5 comes on when trying to bake
Ok, this is a control fault that may or may not be solved by initiating a hard reset. To initiate this reset, you will have to unplug the entire oven for 3 total Min's. it is vital that you allow three total Min's before you power up once more. if you cant reach the actual plug, you can shut of the appropriate circuit breaker as well for three total Min's. Once the hard reset has been initiated, power the oven up once more. If the same problem still exists, you will have to replace the Electronic Oven Control Board.
Please rate and god bless:)
Apr 03, 2009 | Thermador SC302T Electric Double Oven
Mar 14, 2009 | Thermador SC302T Electric Double Oven
F7 error
Jan 11, 2008 | Thermador SC302T Electric Double Oven
Thermador SC301T oven
Thermador SC301T and SC302 stack ovens have a weakness in the radial capacitors on the circuit board behind the LED clock. They get cooked from heat. Here is the fix: Remove two screws from the control panel, located facing up at the bottom on the panel frame.. open the oven door to see them. The panel is then held in place by push in toggles at each end, pull towards you to remove. Carefully unplug the three wiring harness plug-ins, and check them to see if any wires are loose. Set the panel aside. Remove 3 screws holding in the LED assembly, and again unplug the wire harnesses, examining each for loose wires at the terminal. When unplugged, take the LED assembly to the bench, remove the plastic housing, and with a mini soldering iron and watchmaker's eyeglasses, or hobby magnifier,
identify, heat, and remove two 35v 450uf 105 degree radial capacitors, and one 35v 68uf 105 degree
capacitor. These are ordered from MCM Electronics (google it) and are p/ns 96K0326 and 96K0331.
Insert new parts, solder and clip excess leads. Carefully examine the printed circuit board around the area of the leads you just soldered, as some boards do not have the copper close enough to the hole to make contact. Scrape the green insulation from the conductor near the hole to expose copper and make sure your solder makes contact with the copper and the lead. Use your multi-tester when finished to check continuity from all leads you just soldered and their nearest neighboring contact on the circuit board. I found a loose wire on the harness to repair, and one contact on a capacitor did not have the copper close enough to make contact without extra effort. When all is completed, reassemble. Turn back on power at the circuit breaker. You may get an F7 error code. Off with the power again, wait 3 minutes. Restore power, go to oven and press the OFF position on the glass control panel... hold for 10 seconds, and the clock should now be steady at 12:00. Push clock position, reset clock for proper time. Test oven light on/off. Test bake/temp/convection buttons,
on/off. This is a good fix, and will save you about $469.00 in parts and $500.00 in labor. The new
105 degree centigrade high temperature radial capacitors replace old 85 degree, which fail, and your repair should last. Total parts and shipping costs.. about $10.00.
Nov 08, 2007 | Thermador SC302T Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
341 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
