Question about Lenovo 3000 N500 Notebook
Computer locks when starting
I go to f12 and see that it gets to pxe-e61 media test failure check cable then pxe-mof exiting pxe rom and locks up. tried to load from disk got all the way throught to setup is starting windows locks up again
  • 23 Answers
I cannot be sure, but I think that this problem has something to do with having "boot from network adapter" enabled in your BIOS. If this is not the problem, then it might be another malfunctioning device, in which case, you will want to go into BIOS and disable everything except for what you need to get through the restore process(Disable USB ports, network adapter, PCMCIA card slot, etc.)
Posted on Jul 03, 2009
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
Laptop won't start up
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 12, 2012 | Toshiba Computers & Internet
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
Keeps saying boot failure along with Ethernet controller v1.06 and media failure, check cable
What you are describing is a hard drive issue, remove hardware and reseat it back in place sometimes this will restart the hard drive. If this fails have it tested.
Jun 04, 2012 | MSI Computers & Internet
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
I have an emachines e620 and when i switch my computer on it says pxe-e61 media test failure, check cable and it also says pxe-mof exiting pxe rom operating system not found help would be great
Go into set-up and change the boot order to the hard drive you have your operating system on... then cd-rom. you may actually want to start with your cd-rom as it makes it easier when you are installing an operating system.
robert
Sep 04, 2009 | eMachines E620-5885 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Problem with sony vaio laptop
Your Harddisk drive did not detect by your motherboard, try to remove the IDE cable and the power cable to the harddisk and return it back and surely fit in..
tnx
-micro
Feb 09, 2008 | Computers & Internet
Lenovo 3000 N500 Notebook Logo
263 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
