Question about Panasonic PV-GS300 Mini DV Digital Camcorder
Playback has horiontal blue lines through images
I haev been downloading my minidvs to the computer with no problems until I started to get horizontal blue lines through the image - both on the screen of the camera and on my downloaded file on the computer. Unless these lines are being created as I do it, the lines were not on the tape - I checked ones I had done, and the lines are now there.
Re: Playback has horiontal blue lines through images
I have the same problem, it is the heads but i think they are not working anymore, lets fight back!
Posted on Apr 14, 2008
  • 3 Answers
You need to throw away the camera. this solution will save you heartache and time. OR you could spend 300$ on getting it fixed. ITS CALLED a HEADCLEAN. only panasonic will clean the heads but that'll be pricey. i would just invest in a worthy camcorder like the dvx!
Posted on Dec 24, 2007
0 characters
3 Points
I have a Canon ZR90A and started noticing horizontal gray lines displaying across the screen when it plays back. What is causing this?
The most common cause of horizontal lines during playback is dirty heads/tape path. If you have a head cleaner tape, try playing it for about 5 to 10 seconds and then try your tape again. Repeat as necessary. Try not to run the head cleaner for long periods of time because you may wear down your heads quicker (cleaning cassette is somewhat abrasive). If you do not own a head cleaning tape, I highly recommend purchasing one. Sony (in my opinion) makes the best miniDV head cleaning cassette. We use this brand in our repair shop and they last for years. I have posted a link to the particular tape I am speaking of. Your local camera/camcorder shop may have these for sale.
Hope this helps you.
Sep 12, 2010 | Canon Video Cameras
During playback there are 5 horizontal blue lines that display. Can I fix this myself?
try with head cleaning cassette 2 or 3 times if problem presists change video head assembly
May 20, 2010 | Panasonic PV-GS150 Mini DV Digital...
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Nov 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
JVC Camcorder
Put an used casette inside; hit PLAY and then FFWD until you start seeing images. Eventually you will start seeing some with lines and then the black lines will get smaller and smaller until they turn into grainy lines. Stop and PLAY again and they will faint. RWD and PLAY back as you wish and it should be find. I think this is because of tiny dirt particles that your cassette will dust off for you.
Aug 26, 2008 | JVC GR-D270US Mini DV Digital Camcorder
Blue Horizontal Lines
if you dont have time to get it fixed, tap on the side where the tape goes in. I had to tap it a couple of times before everything started work fine again.
May 06, 2008 | Panasonic Palmcorder PV-GS15 Mini DV...
Panasonic Digital Video Camera (Mini DV) - horizontal stripes
I am having the same problem with my Canon Optura 60. But only in playback.
Jan 08, 2008 | Video Cameras
Can't upload video on PC
the computer might not automatically upload the file. it will detect the hardware, but not necessarily start uploading. if you have xp, try going into movie maker which is in your program list in the start menu. on the left hand side there is a few blue sentences, one is import video, another is import video from device. if you have your camera connected to the computer through firewire and have your camera on the vcr/playback mode, open movie maker and click import video from device, the computer will have already detected your camera, so the first option your given in the next screen should have the make and model of your camera to upload from.
Aug 27, 2007 | Panasonic PV-GS19 Mini DV Digital...
Sony DCR-TRV230E Digital 8 Playback Problem
Hi! If the images you are capturing are hazy with zig zag colors etc...the imaging IC is faulty.If the problem in Display unit only but the captured image is OK when you transfer the same to PC..then LCD may be having problems. We can help you in spares of Sony and we can also offer the service manual. Kindly let me know after your examination. Regards, Sivaram.V Videolabs
Nov 28, 2006 | Sony Handycam DCR-TRV240E Digital...
Panasonic PV-DV702 Garbled playback - any solutions??
Try a different tape. The tape itself may be bad.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Panasonic PV-GS300 Mini DV Digital Camcorder Logo
400 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
