Question about Locks & Locksmithing
Multi point upvc window lock mechanism broken with bottom point not moving and window closed. How can i open window?
My windows are playing up, one window lock is stuck fast on the handle and the other one the lock has broke and it is very windy and i dont know how to shut it. Something has came out of the lock at the back it never shuts my room is freezing, Hlp and how much to fix them both.
Thank You
Posted on Feb 12, 2014
Power lock does not work on rear door
Power door lock mechanisms required periodic lubrication to work correctly. Without periodic lubrication, the mechanisms stick and, eventually, the lock solenoid will fail and require replacement. As a rule, the power lock mechanisms and power window regulators should be lubricated every two to three years.
Begin by removing the door panel and lubricating all points of the lock mechanism, including the solenoid plunger. If that does not correct the condition, look for broken parts and mechanical obstructions. Manually move the solenoid plunger to make sure that the mechanism is not seized. If the mechanism will not move, detach the mechanism from the actuator solenoid and see if the solenoid itself has seized.
Check that the lock solenoid is receiving 12V when the LOCK/UNLOCK button is actuated. If not, trace down the electrical fault. If the mechanism moves freely, and there is voltage at the connector when the switch is actuated, the solenoid has burned out and should be replaced.
Jul 23, 2014 | 2005 Dodge Caravan
Which one is best between UPVC and Aluminium Doors & Windows?
I will prefer UPVC windows and doors because it is much advantageous than aluminum. Some points are given below-
Maintenance
Aluminum windows and doors need painting over long periods of usage whether UPVC windows and doors requires no painting; only routine cleaning.
Durability under Extreme Weather
Aluminum windows and aluminium doors can start fading after sustained exposure to sun. Start looking ugly. But, UPVC windows and doors have UV resistant blend; do not fade under sustained exposure to sun.
Aesthetics
Aluminum windows and aluminium doors can look cold and out of proportion whether UPVC windows and doors have elegant looks; enhances both; the exteriors and interiors of the building.
For detailed information visit: http://www.fenesta.com/aluminium-windows-doors.aspx
Dec 05, 2013 | Scotch 600 Film Tape,upvc,clear,3/4 In. X...
Where can I purchase quality UPVC windows and doors in Bangalore?
Fenesta Building Systems is India's largest windows and doors company. It has installed more than a Million windows doors across nearly 150,000 homes. This will be best for you to purchase UPVC windows or doors in Bangalore. To find your nearest dealer visit: http://www.fenesta.com/dealer/upvc-windows-doors-bengaluru.aspx
My drivers side rear door is locked open and I
check the closing mechanism and see if it isnt locked down in the closed position, if it is stick your finger in there and pull it out like it would open while moving the door handle, if thats not the problem, see if there isnt a toy or something stuck in the tracks on the bottom or dirt and leaves on the top
Jul 04, 2010 | 2002 Chrysler Town & Country
The sliding door on our 1996 Toyota Sienna is broken shut (it cannot be opened). The door button on the inside nor the handle on the outside can mechanically effect the door. We do not have automatic door...
It sounds like the cable/bar in the door is broken or stuck
1. you will need to remove the door lining to get at the problem
2. could also be the door lock stuck in the lock position (does the door feel like it locks or unlocks when you use the lock)
3. could be the handle cable/ bar
NOTE some vehicles have cables while others have bars play with everything while you have the guts exposed this should help to locate the problem if nothing is moving while you play with the lock or handle this could be the problem
NOTE If nothing seems to be missing or out of place it could simply need to be lubed at the point where the door locks to the frame
Aug 21, 2009 | 1998 Toyota Sienna
Okui 3530 toner sensor error
turn off eq - open and remove the drum with the color cartridge in locked position still in place - on the drum on the cartridge lock side you will find a small (1/4 ") rectangular "window"...with the catridge in locked position the window should be open so you can see the sensor...when the cartridge is unlocked the window should be closed...so with the cartridge locked, using a tiny pointed object (paper clip), gently move the panel up or down to the open position (mine moved up)....replace the drum with cartridge...make sure it is set properly...close up everything and turn eq back on....you may have to do this two or three times to make sure the window stays open when the lock is engaged...but this is what the "tech"(salesman) did...good luck
Nov 10, 2008 | OKI C3530N Color MFP Printer
N Reg Ford Escort Cabriolet, locking mechanism
By 'Black bar' do you mean the window guide? If so, this is usually held in place at the bottom by a bolt or screw &, once removed, the guide should pull out downwards. The window should be closed. Your latch might have a black, anti-theft cover on the inside of the door which will also need to be removed.
Jun 27, 2008 | 1996 Ford Escort 4 Door
Locks & Locksmithing Logo
1,111 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
