The pump is usually located close to the tank. (look in a compartment, under bed etc) It is pressure activated (pressure switch) so if it has already built up its pressure it will turn off / not run. One way to check this is (unhook city hose) open a faucet. --- Could be the pump is shot, or the pressure switch is defective.
One way to locate the water pump is to turn on a facet and then turn on the water pump. You should be able to hear it run as it tries to "catch up" on water flow/pressure. Look where the sound comes from. You can find the water heater from outside the RV by looking at the walls for a access door that has a screen on a portion of it. This will be the location of either the water pump or the furnace. If furnace, look for another such door.
