Zanussi zwf 1020w keeps over filling then cutting out
Spins and drains fine.
when put on a normal wash cycle though, the water keeps filling almost to the top of the drum. Then goes straight to end cycle with 4 flashed, implying that the door is open (obviusly is not, must be as the pressure is v high).
How do i stop it?
  • 31 Answers
Hi it sounds like your pressure valve is on its way out or you have a block in the little pipe best way to see if you have a blok in your pipe is take the top off your washer and find your pie is only thin going in to a round valve take it off and with some water in the drum blow down it if there is bubbles comeing up i would get a new valve hope this helps stuart
Posted on Jul 03, 2009
Washer skips rinse cycle
Possible defective washer control panel.
Jul 13, 2017 | Zanussi Washing Machines
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Zanussi ZWF 1021 W The door won't release after the end of any cycle, even empty or spin. What can I do to get the clothes out?
First thing would be to check the filter at front of machine as any blockage will cause this problem.
Try this and come back for further assistance.
Dec 06, 2008 | Zanussi Washing Machines
Zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
