Bought ram 256 modules and installed them but only getting 128 from each is there a setting in the bios or a pin setting on the motherboard.
  • 1,684 Answers
Some motherboards will not see double sided memory modules correctly. Check the motherboard manual or manufacturers web site to be sure. If the board does not see double sided memory then it does just what you are talking about(only sees half the memory size).
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 04, 2009
Will a Samsung 256MB DDR PC2700 CL2.5 184 PIN work
No that memory is not compatible. The Precision 350 uses memory called RDRAM aka RAMBUS.
Here are the speeds and sizes that are supported.
Memory modules supported PC800-40: 64-, 128-, 256-, 512-MB, non-ECC or ECC
PC1066-32P: 128-, 256-, 512-MB, ECC and 64-, 128-
,256-,512-MB, non-ECC
Minimum memory PC800-40: 128 MB non-ECC and ECC
PC1066-32P: 128 MB non-ECC and 256 MB ECC
Maximum memory PC800-40: 2 GB non-ECC and ECC
PC1066-32P: 1.5 GB non-ECC and ECC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/benjamin_29adbb94bfb43281
Sep 27, 2014 | Computers & Internet
I have intel D845 Mother board with 4 memory (ram) slots one I am using is 256 KB SD RAM & I want to use one 128 KB SD Ram is it possible to use both Thanks.
Hello yeah, you can use both RAMs if they are compatible in terms of bus speed and type like DDR1.
Different types of DRAM modules (eg. DDR200 and DDR266 DIMMs/PC100 and PC133 DIMMs) should not be installed on one motherboard at the same time. This motherboard supports memory modules with capacities of 64/128/256/512MB and 1GB.
Hope this helps
Jan 17, 2011 | Intel Motherboard
My System is not showing correct RAM, i.e.,128 MB instead of 256
the ram you've purchased is high density ram, not supported by your motherboard....sorry :(
I suggest www.crucial.com to make sure you get the right type for your system.....
Apr 10, 2009 | Computers & Internet
Presario won't recognize second 256 RAM
Remove the original module, install just the new one and then start your computer. If it doesn't start, the memory you bought is bad. The system boards used in the Compaqs will auto-detect memory, and there are no jumpers or BIOS settings needed.
Apr 09, 2009 | Compaq Presario 5000 PC Desktop
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Ram when i upgrade 128 sdram to 256 sdram in intel 845glly it shows spd
It is not seieng the ram, try swapping the ram around or leave out the 128MB, just put in 256MB, if no boot then the ram is not compatible or faulty, not all ram sticks work in all motherboards.
Sep 08, 2008 | Intel D845GLLY Motherboard
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
Bios upgrade?
You might consider replacing your ram with ALL the same RAM cards. I don't know what the maximum RAM is that you can add to your motherboard, but I have read that some BIOS programs can't read cards that are different amounts from others. Don't exceed the recommended RAM for the motherboard, either.
Jan 09, 2008 | Delta Enterprise Slot 1 M81-X Motherboard
Computers & Internet Logo
52 people viewed this question
Alun Cox
David Payne
David Payne
