Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
No Gas I have a craftsman 17.5 42 cut rider model 017272461. Won`t start. you can pour gas in carb and it will run and quit. Fuelpump, carb ? stumped.
  • Durwood48 Jul 04, 2009
    Thanks Longhorn. i`ll take it apart. A question about that so called fuel pump. I don`t see how it works, its not electrical, it has an inlet, outlet and a hose going to a box where a set of valves are. When I unbolt the pump and lower it into a bucket, it flows gas out steady so how does it work. The line goes up to the pump so how does it work?
  • 3 Answers
I had the same problem on mine as well...it was the fuel line itself...it was deteriating from the inside and small pieces of rubber was blocking/clogging the line. Replaced the fuel line and works great now. May not be your problem, howevr lots of people forget about the fuel line going bad....
Posted on Jul 16, 2009
  • 376 Answers
Most probably the carb restricted by varnish, trash or rust. Need to clean carb. You'll probably see the problem when you remove the bowl.
Posted on Jul 03, 2009
Gas pours out under craftsman riding tractor
Is it a leak in the tank or is it a loose hose?
Jul 24, 2015 | Craftsman Garden
Craftsman gas pressure model#580-752220 willnot stay running. Only after you push the primer 10-20 times it will start &run for 5-10sec..It will run if you pour gas in carburetor.If you quit with the...
Sounds like the idle jet in the carb is plugged up.
It only stays running from the primer load, then dies when that is used up, as the gas can not get from the float bowl through the idle jet.
Did you store it for a while with the gas still in it?
If so, what happens is the gas starts to go bad, and over time it can get almost like a varnish.
When this happens, it starts plugging up the small ports in the carb, starting with the smallest, which is the idle jet.
Before storing for any length of time, your best bet is to drain the gas and run the float bowl dry.
If not that, at least add some fuel stabilizer to the gas left in it, and run it for about 5 minutes with the stabilizer in the fuel.
May 31, 2014 | Cars & Trucks
Engine stalled out,would not start, pour gas in carb,cranks,keeps running,until idle falls below 12to1500rpm,than stalls out again and will not crank,repeat gas or starting fluid in carb,cranks runs and...
This truck is fuel injected, the problem sounds like a weak fuelpump, it runs when you pour gas into it until that gas runs out, the first thing is to test the fuel preasure, if the pump is weak it may run with gas poured into it but wont idle, also a common problem is the coolant temp sensor and the ground wires to thermostat housing bolt but i wont bet its the pump inside the fuel tank, if you put a fuel gauge on it there should be at least 55-61 psi if its a few pounds lower it can cause problems, you have everything else and it runs with gas poured so its a fuel problem check the preasure, theres a valve up top on the fuel line to connect a fuel gauge to it, start there hope this is helpful.
Dec 27, 2010 | 1993 Chevrolet C1500
I was driving down the road and the truck just quit. it cranks very well, but no intentions of turning over. i checked the spark,good but even when i puur gas in the carb. nothing happens
this sounds like a bad fuelpump, try spraying starting fluid in throtle instead of pouring gas, when you pour gas it may not enter all cylinders it may just sit in intake galley. try the starting fluid.also have someone crank the engine while you beat on bottom of gas tank with a rubber hammer, this sometimes shakes fuelpump and make a contact to get pump going again.
Jul 21, 2010 | 1997 GMC Sonoma
Carburator floods
Possibly the needle valve in the carb. fuel bowl.
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 42in rider quits after about 30 to 45 minutes. The carb solenoid is good and the gas cap is venting ok. I have to wait about 20 to 30 minutes before it will start again. What should I check...
try the coil,does it get fire to the sparkplug after it quits and what color is the spark? blue spark is good, red is weak fire, and not enough to fire the engine up.
20 hp craftsman lawn tractor (2006) stopped running while mowing. tried to restart . ran for 2-3 seconds and quit. could not restart. fuel running free through filter all the way to carb. pouring fuel in...
I would take the bowl off the bottom of the carb.. Probably you have clogged up holes that let the gas into the bowl.Or either the needle is stuck up not allowing the gas to flow...That's why pouring gas in carbs would let it run for s few seconds....Also try fresh gas..Gas doesn't have led in it anymore..It don't last year from year...After grass season is over..Buy some from Lowe's or home depot..Pour it into your tank and let the motor run to get it done into the carburetor...Then the next year it will start
Jan 12, 2018 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Won't start after killing the motor
May need more info. Check for a seat switch to have came unpluged (wiring) this is a safty thing. You have to have your foot on the brake as you sit in the seat to get it to crank. repost if you need more help.
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
17 hp craftsman rider will not start
The carb needs to be taken apart and cleaned.
May 20, 2009 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
172 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
