Question about Refrigerators
My Magic Chef mini fridge (model MCBR445B1) stopped working. When it is plugged in, there is an occasional clicking noise and the compressor gets hot, but it doesn't run.
  • cgargan1 Jul 03, 2009
    If the problem has to do with wiring, I'm not much of an electrician, so I would need specific instructions on how to identify the wiring problem.
    Thanks for forwarding the link to that article - - it seems to describe my problem and its symptoms exactly. However, when I removed the start relay and shook it, I didn't hear any rattling, so I'm not sure that's the source of the problem. I did as the article suggested and used an ohm meter to test the the resistance between the pegs on the control pod of the compressor, but I didn't get any infinite resistance readings, nor did I get any reading when I measured from the compressor pegs to ground, so apparently the compressor itself is not "FUBAR". Any suggestions on what to do at this point? Is it most likely a bad start relay and I should just try replacing it?
  • 97 Answers
Hi!... Remove the cover on the back of the fridge and look at the compressor start device.
If it looks like a cube - remove it and shake it. If it makes a rustling sound then the start device is bad. Change it... Hope I Helped...
Posted on Jul 04, 2009
    Genius:
  • 1,847 Answers
This link will help you..
http://fixitnow.com/wp/2005/12/01/refrigerator-warming-up-and-makes-an-occasional-clicking-noise/
Let me know if you need further assistance
Thanks
K
Posted on Jul 03, 2009
    Sergeant:
    Champion:
  • 212 Answers
Just check the entire wiring it will be due to short off the wire so pls check the wiring and coil
Magic Chef Refrig Model MCBR445B1, the motor/fan/compressor is not running when plugged in.. It is approx. 5 years old. Is it worth repairing?
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 24, 2010 | Magic Chef MCBR440 Compact Refrigerator
My Magic Chef Mini Fridge just stopped but the compressor is hot.
ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Aug 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
Aug 26, 2009 | Magic Chef MCBR440 Compact Refrigerator
My mini fridge will not work. compressor is hot.
Believe you need to change the start relay and overload, Sea Breeze
Aug 23, 2009 | Magic Chef MCBR440 Compact Refrigerator
MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Jun 29, 2009 | Magic Chef MCWC16MCG Wine Cooler
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic chef compact fridgerator model mcbr445b1
you may just have a bad relay. with the power removed ..(unpluged)
remove the relay cover ( on the side of the compressor)
remove overload and relay
check relay for 4-5 ohms
check overload (if open it is bad)
let me know
Dec 21, 2008 | Refrigerators
Refrigerators Logo
875 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
