Question about Palm TX Handheld
BOTTOM OF SCREEN NOT WORKING,
The bottom of the screen does not recognize stylus, as you get to bottom of screen, stylus marks progressively higher. Calibrating touchscreen does not work, soft reset and even hard reset did not solve
This happens a lot with Palm digitizers. The only permanent solution is replace the plastic digitizer with an upgraded glass type. Before considering that, see if removing screen protector helps. (yeah, didn't think so. Worth a try!) Try Powerdigi, a better calibration program. Get it from http://www.palmpowerups.com
It worked for me.
Posted on Jul 07, 2009
Irulu recognizes finger but not stylus
Have you tried a stylus for capacitive screens?
Apr 09, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Olympus master will not recognize my stylus 710
The software for your camera is outdated and not supported by the later version of Windows, If Olympus does not have a later version on their website you are out of luck. Windows Vista had a lot of issues. My advice would be get rid of Windows Vista and install Windows XP.
It is far better.
Jan 21, 2013 | Olympus Stylus 710 Digital Camera
A740GM-M recognizes DEL or F11 keys but then fails to go into either mode. Have motherboard out of case, one stick memory recognized properly. What can I check/do? System worked just fine until server...
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, using the arrow keys highlight Safe Mode and press Enter. Wait for your desktop to appear, where the only things working will be your mouse and keyboard enabling you to make the necessary repairs eg: click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your motherboard to your hard drive or just replace them they could be faulty
hope this helps
May 16, 2011 | EliteGroup ECS A740GM-M Value Socket...
Question mark appears on screen when I put a game inside of it.
  • Try calibrating the screen
  1. Turn the Leap Pad off.
  2. Now hold the question mark button for two seconds and then power the until on while still holding the question mark button down.
  3. The unit will power on and when you see the "calibration Screen" you can release the question mark button.
  4. Touch the crosshairs with the stylus and a large crosshair icon will appear in the middle of the screen.
  5. Touch this icon with the stylus and this will bring up the screen calibration procedure.
  6. Touch all 5 crosshairs as the appear.
  7. Press the "B" button to exit after completing the calibration.
Regards, Tony
May 11, 2011 | Leapster Learning System
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges ' eHow.co.uk http://www.ehow.co.uk/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz1YgKjqw42
Instructions
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Mar 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I recalibrated the leapster2. It recognizes the stylus on the calibration screen. When I reboot it still doesn't recognize the stylus at all. Please help.
If your Leapster does not respond to the stylus pen, it needs to be calibrated.
The following are instructions below on how to recalibrate the leapster.
1. Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.
2. Hold down the Home, Hint and B buttons simultaneously.
3. When the screen changes, press the A button.
4. Using the Stylus, touch the center of the targets.
Thanks for using Fixya.
Feb 06, 2011 | LeapFrog Leapster Electronic Book:...
Ds stylusthinks its pointing at another area of the screen
calibrate the touch screen ....start your ds with no game in it and click on the small ds at the bottom of the screen,next ,touch the yellowbox on the right and follow the calibration instructions.......if you cant get it to work then change the touch screen......good luck
Feb 16, 2009 | Nintendo DS Console
Leapster 2 Doesn't Recognize Stylus
Hold the hint button (question mark) when turning on the device. When the device turns on, do the stylus calibration and touch each of the crosshairs that shows up. After you are finished restart the leapster and you should be fine.
Jan 03, 2009 | LeapFrog Leapster Electronic Book:...
Black (no colour) printing setting Ebson Stylus CX4800
Ask to print,when printer screen comes up go to properties on the top right then advanced on the bottom right (it'll ask if you really want this --you do) then on the bottom left there is a box to mark for black and white only
Jul 31, 2008 | Epson Stylus C66 Photo InkJet Printer
Palm TX Handheld Logo
266 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
