Question about Ruud UAMB Air Conditioner
Fan motor not I have two caps and dont know which
Fan motor not runing I have two caps and dont know which one is run/or start
    Problem Solver:
  • 16 Answers
First pull the quick disconnect (power source). If you have a multimeter with capacitor check (uf) capabilities, look at the side of the capacitor and see what the uf rating is, (should be somthing like 3.5uf or 5.0uf or7.5uf) then stick a screwdriver between both contacts where the wires are pluged into the top of the capacitor and touch both contacts at the same time to discharge any stored electric power, then remove all the wires from the top of the capactor, switch on the multimeter and set it to the uf setting, now place one lead on one side and one on the other, if your capacitor is say a 7.5uf and the reading is 9.0uf or 6.0uf it's bad replace
the capacitor. check both of your capacitors the same way, oh mark your capacitor and the wires so you can put them back together rite. If you don't have a multimeter with capasatence checking capability take them to an appliance shop and let them do it for you.
Posted on Jul 03, 2009
Fedders 208/230 split system w/ dual cap , compresser runs but fan wont unless you give it a push , compresser won't restart if relay is hot
All kinds of stutt happens when you dont have a condensor fan motor. You need to change the run cap on the motor.
Aug 06, 2011 | Heating & Cooling
After Eng is turn off A/C & heater fan keeps runing dranig
The fan runs off a module incorporated inside the blower fan motor. The motor assembly will need to be replaced for its all electronic inside
Jun 22, 2010 | 1996 Buick Park Avenue
A/C MOTOR STOPS RUNING AFTER 10 MI I REPLACED WITH NEW FAN MOTOR AND CAP
Run the motor as long as it will run, carefully feel the motor and see if the case is extremely hot, if so, the internal safety is tripping to protect the motor, after a cool-down period the safety should reset. If this is the case, verify proper Horsepower rating, rotation of the motor, proper amp draw during operation and proper capacitor connection and size. Hope this helps.
May 08, 2010 | Coleman Mach 15 Air Conditioner
My air conditioner fan motor runs in reverse thus, none or very little air is coming out
The fan motor can be wired correctly for up flow and still run backwards for downward flow or reverse when you put the wrong value capacitor or connect a hard start capacitor to an already bad start dual cap. Case in point: I come across a condenser where the fan motor is running (in the right direction, up) but the compressor is not. I put a hard start cap on the dual cap. The compressor comes on but now the fan motor runs reverse. No other wiring was changed. The hard start cap connected to the defective compressor start cap shifted the current, voltage phase 180 degrees to make the fan motor run backwards. I removed the hard start cap, removed the defective dual cap and replaced the dual cap with a known good one and everything worked correctly.
Jul 09, 2009 | Heating & Cooling
Have to manually help fan to start rotating
Nope, run capiacitor, fan motors don't use a start cap only compressors. However, the problem is most likely bad bearings in the motor and the motor needs to be replaced. If the run cap were bad you would have high amp draw when the motor is running and would trip out on overload or burn the windings.
May 01, 2009 | Coleman Mach III Air Conditioner
Outside Fan Problems
TRY CHANGING THE CAP FIRST BUT MOST UNITS ONLY USE THE CAP TO START THE MOTOR NOT TO KEEP IT RUNNING SO IT SOUNDS LIKE YOU HAVE A BAD CAP AND THATS WHY IT DOESNT START HOWEVER IF IT STOPS RUNNING WITHOUT THE THERMOSTAT TELLING IT TO (OR IN THE MIDDLE OF A CYCLE) THEN YOUR RUN WINDING IN YOUR MOTOR IS GOING BAD YOU CAN REPLACE THIS MOTOR PRETTY EASY AND IF YOU USE AN AFTER MARKET INSTEAD OF AN OEM MOTOR YOU CAN SAVE YOURSELF ALOT OF MONEY. PS BE CAREFULL WHEN CHANGING YOUR CAP BECAUSE EVEN WITH THE POWER OFF IT CAN SHOCK YOU.AFTER SHUTTING THE POWER OFF USE AN INSULATED SCREWDRIVER AND TOUCH IT ACROSS THE POLES AT THE TOP OF THE CAP TO GROUND IT AND REMOVE POTENTIAL ENERGY.
Jul 22, 2008 | Weather King 10AJA2501AH Air Conditioner
PORTABLE A/C
I WOULD TRY TO INSTALL A HARD START KIT ON THE CAP IF YOU CAN SPIN IT AND IT RUNS LIKE YOU SAID WHEN YOU FORCE IT TO RUN. IT SOUNDS LIKE THE START CAP IS NOT STRONG ENOUGH TO START THE MOTOR WHEN IT HAS BEN RUNNING. A HARD START HAS TWO WIRES AND IS EASY TO INSTALL
Oct 25, 2007 | Heating & Cooling
Airconditioner problem
This unit has a bad Start/Run Capacitor or a bad Fan Motor! Replace the $10 Cap...An then the $90 fan motor if the Cap dont solve it!
Oct 01, 2007 | Heating & Cooling
Ruud UAMB Air Conditioner Logo
166 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
