Question about Husqvarna Garden
How to remove mandrel shaft on husqvarna YTH2046 K riding mower
  • 376 Answers
Remove nut on top of the pulley and the shaft will come out the bottom with blade attached.
Posted on Jul 04, 2009
  • Jungleboot Apr 15, 2012
    What if the star is stripped on the bottom and you can hold shaft from moving. I've tried everything, but the nut on top of pulley won't budge.
How do I remove the mulcher fro mmy Husqvarna GTH260 to get it to just cut?
Posted on Jun 02, 2010
Excessive vibrating
Exsessive vibration is normally attributable to the mower deck. If the vibration is occurring while the blades are engaged and cutting this would indicate a need for further investigation. Check the blades for damage or uneven ware. If the blades are new or appear in good shape check the mandrals and shafts to ensure they are not Brocken or bent. You can get mandrel assembly's for around $60.00 online and replace all you need in one go.
Jun 14, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
How to take mandrel off a mower
Remove deck, remove the bolts hold it on.
May 24, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mandrell nout
using a copper drift and a hammer place drift on nut or shaft and give it a good welt. maybe need a couple of belts if that fails you may need to use heat
Nov 19, 2013 | Husqvarna Garden
How do you remove the bolts on the mandrel cover of the mowing deck. The bolts begin to loosen but then seem to get tight again.
I would keep turning them, there may be old grass, dirt, etc. that's making them turn harder. If not look underneath deck to make sure theres no nuts on bolts.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 09, 2013 | Husqvarna YTH26V54 54"" Riding Lawn Mower...
YTH1746 how to remove shaf/bearing from mandrell
PUT HOUSING IN VISE CAREFULL, NOT TO TIGHT. PUT NUT
ON SPINDLE TO SAVE THE THREADS, HAMMER IT APART.
Sep 10, 2012 | Husqvarna Garden
How to remove shaft assembly from mandrel housing of a husqvarna yth2348
It's much easier to do on the tractor.
1. Leave deck installed.
2. Jack tractor up and lower deck.
3. Run a heavy wire through the mandrel pulley's tie down hole.
4. Raise deck and tie wire around the deck.
5. Lower deck and remove top nut.
6. Raise deck and remove shaft.
You can modify this procedure to loose the nut if you don't have a jack and remove it once the deck is off. Retorque nut to 35 ft. lbs during install.
Apr 25, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How to Replace v belt drive
For the YTH2246 only...
1. All you need for this job is a small 1/4" ratchet and a 3/8" socket to install/replace the 1/2" X 106" V-belt [(no. 68 in the mower deck schematic for this tractor) Husqvarna part # 532 40 51-43, Sears part # 33156, Rotary Outdoor Power Equipment Service Parts part # 912106 (12-7549)] ($36-$42)
2. Total time for this DIY job: about 15 minutes.
3. Lower the deck by moving the manual height adjuster to the lowest position (position 1).
4. The only screws you really need to remove are the rear retaining 3/8" hex-head screw of the LH cover mandrel and both from the RH mandrel cover. Just swing the left-side cover out to get access to the LH pulley.
5. Slightly pull from pulleys the legs of the keeper belt mandrel LH/RH to remove/insert the belt. Did I mention you don't need to loosen/remove any screw other than the ones mentioned above?
6. For more assistance, take a look at the schematic in the owner's manual or online at http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602060.pdf
Mar 02, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How can I un-bolt the Mandrel Pulley from the shaft?
If you have the deck removed from under the tractor you can try putting the blade back on tight if you have removed it and then use the blade to keep the mandrel shaft from turning. It takes quite a bit of torque to break the nut loose on the pulley so a socket and ratchet or breaker bar is the best thing to use. Other than that there is no "special" tool required
Sep 26, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
657 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
