Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
88 flashes on display screen
I cannot remember how to set the timer on our Intex saltwater chlorinator. Seems like you have to hold down 2 buttons or something... please help
  • 297 Answers
Hold the down arrow till it beeps then hold the up arrow till it beeps When you see double zero then set the # of hours you want it to run with the up and down arrows.
Then you will need to lock it in use the down arrow again and wait for a longer beep then the up again till a long beep.
You are set remeber that it will take about 5 minutes for the chlorine light to come on
you can also go to intex.comm and watch the video or read the manual
Posted on Jul 04, 2009
I just connected my sale water pump and can not remember how to program it. 88 is on the display and when i press on the up and down button it just beeps? help. di
start by holding down arrow until it beeps
now hold up arrow ti'll it beeps
now push up arrow with quick pushes to set hours
now your choice to lock it
either leave it alone for 2-10 minutes and it will lock and go to seccond green light
or repeat step 1 & 2 and still wait 2-10 minutes for the chlorine light
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 29, 2010 | Intex Automatic Salt Water System for ...
I bought my saltwater chlorinator from an individual. They did not have the book. It reads 88 is that right? The number stays the same
That # is right for str8 filtering
Setting for chlorine generation you need to
Hold down arrow till it beeps
now hold up arrow till it beeps
while 00 is flashing quickly push up arrow till it goes to the hours you want it to run
Now repeat the arrow sequence
Jun 30, 2010 | Intex Automatic Salt Water System for ...
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
WHAT DOES IT MEAN IF THE GREEN LIGHT IS NOT ON? DOES THE SYSTEM REST AFTER THE TIME HAS RUN OUT, MY SYSTEM HAS 88 DISPLAYED
88 means you are filtering alone no chlorine
Once the generator is set it will run its time like 1-12 hours depending on what you set it at
After this time it will flash 93 meaning it is getting ready for sleep mode eventually it will shut that down and then turn back on at the same time you programed it the time before
There are 2 green lights
top one is that you are filtering
second one comes on about 2-10 minutes after you set the generator time this shows you are producing salt
Jun 14, 2010 | Intex Automatic Salt Water System for ...
My led lights up 88 but when i push the buttons to unlock pad and set timer it wont do anything
are you holding down the pads long enough to hear a beep? hold down arrow till it beeps then hold up arrow till it beeps then set your hours with the up arrow
now let it lock itself and turn on.
This will take 2-10 minutes keep looking for the second green indicator this lets you know it is gen erating chlorine
Jun 12, 2010 | Intex Automatic Salt Water System for ...
Forgot how to set the timer getting 88 dont know where to go from here
88 is filtering
When you want to generate chlorine hold down arrow till it beeps hold up arrow till it beeps now with up arrow set desired hours no repeat the steps listed above that will lock it in now wait for 2-10 minutes until second green light comes on
Jun 09, 2010 | Intex Automatic Salt Water System for ...
I have installed my Intex Krystal Clear Saltwater system for my above ground pool and have run it for 12 hours. I want to run it another 12 hours. How do I start the system again instead of waiting on the...
First of all you should not have set it to generat chlorine until straight filtering for 24 hours. unplug then plug it back in
88 will appear let your salt disolve by filtering only for the 24 hours then proceed to generate chlorine
It may look disolve but there are many hot spots that need to get distributed eveny
Jun 07, 2010 | Intex Automatic Salt Water System for ...
I have an intex salt water filter, what is code 88
It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
Jun 03, 2010 | Intex 2000 GPH Salt Water Filtration Pump...
Code 88
Plug the pump in. You will see code 88 which is normal. Press and hold the down button for 2 seconds until you hear a short beep.Then press and hold the up button for anohter 2 seconds until you hear a short beep and the LED flashes 00. Using the up button set the time to run based on the size of the pool which you did not list. Tell me the size and I will tell you how many hours to set on the timer. You can download an owner's manual here: http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Intex pool chlorinator trouble with unlocking mechanism
do not get frustrated with the long phone call.
Get your receipt ready and you could have a new filter in a week
CALL THEM BACK
They are good about these things
Mine arrived in 5 days no questions asked. I didnt even have to send the old one back
Keep as many parts from the old as you can especially the electro cell that is 200 bucks by itself
Jun 27, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
266 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
