Question about Craftsman Convertible 25cc. Gas Line Trimmer
Starts but wont stay running with out the choke pulled out halfway.
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Jul 03, 2009
  • 1 more comment
  • Jim Parker
    Jim Parker Jul 06, 2009
    Did this solution solve the problem?
    Jim
  • whitehouse60 Sep 21, 2010
    Where are the portals that can become blocked. not on their parts list.
  • Jim Parker
    Jim Parker Sep 22, 2010
    When you take the carburetor apart, you will see a number of very small holes (portals). Use the Den Tek brush to clean these portals. Dirt particles get lodged in them, not allowing fuel to flow properly. As soon as you get these cleaned out, reassemble and start.
2 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Posted on Jul 02, 2008
04 330 magnum will not stay running without choke pulled out halfway to full choke from brand new in 2004
First make sure the carb.mounting flange is tight. being loose or cracked will allow air in leaning out the air fuel mixture. Next remove the low jet in the carb. its most likely plugged. try carb cleaner and blow it out with compressed air. Last resort,take the paper off of a twist tie and run it through the jet. If all else fails,buy a new one.thier only around 4 dollars.
Dec 14, 2014 | Polaris 2004 Magnum 330 4X4
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
How do I start it? Choke halfway out?? All way out? Has NEVER been used and am looking for starting instructions
Full choke, pull EXACTLY seven times, on 7th pull, engine should spit at you, go half choke. Should start on the next pull.
Sep 10, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Bought a McCulloch M3414 started okay yesterday wont start today maybe I flooded it, pulled cord so many times
1. set on/off switch to on, 2.prime it first, push the bubble about 6x 3. pull the choke all the way out, 4.pull trigger and string simultaneously 5. push in choke halfway try again, pull choke back out and etc. should start after repeating steps 4 and 5 3x or 4x when it does start, pump the gas at half choke then let it idle untill it stops push in choke all the way and it should start. don't forget to check the safety bar in front of the handle usually works with most gas operated tools
Jan 04, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I cant start my leaf blower
I would suggest a new plug and fresh gas and oil mix.push the primer bulb 8-10 times and turn choke to full.pull cord about 4 or 5 times until it starts.if it don,t stay running turn choke to half and pull cord until starts should stay running.let run for about 10 seconds then turn off choke.Almost forgot that during this whole process you hold throttle wide open.
Dec 08, 2010 | Garden
Hard starting on a Makita line trimmer? How do I solve this issue?
Try pushing the primer 8-10 times hold the throttle wide open and turn choke too full.when it starts it will probably quit turn choke to halfway and start again.should stay running.If that don,t work carb needs to be rebuilt or replaced.
Nov 29, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
04 polaris wont stay running without choke on
You will have to replace your pilot jet. thanks, Jason
Dec 01, 2009 | Polaris ATV
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
Craftsman Convertible 25cc. Gas Line Trimmer Logo
562 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
