Question about DCS BGA27-BQ (NG) Grill
DCS BGB30 BQAR doesn't appear to be getting an natural gas flow
No gas is coming out when burner turned on. Values are on. Is there a safty value that may need to be reset?
  • 60 Answers
Its most likely the ng regulator has gone bad you can get one from most grill stores if you dont know of any call bbq galore 214 696 0030
Posted on Aug 20, 2009
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Burner on the top of the stove does not light,doesn't seem to have gas flow
i have the same problem with mine but i was cleaning mine with mr muscle which got in the holes where the gass comes out. i havent found a fix yet. im just hoping it will dry out n start working again
Jul 05, 2012 | DCS RGS-486GL Stainless Steel Gas Kitchen...
Knob too hard to turn on and off burners
This would need greasing the controls dry out and you get brass on brass take the control knob off there are two screws you can remove and take the plug out and grease it with black control grease . then replace this should then work .
Aug 31, 2011 | DCS BGA36-BQAR (LP) All-in-One Grill /...
Model #14116670 bq grill low (and sometimes no flame).Sometimes 2 out 4 burners work well
The problem you're having is the result of the OPD (Overfill Protection Device) Vale in the grill tank.
This occurs when the gas tank valve is opened to fast. Or the tank is low on gas.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the exact same way. Do all the burner flames look correct? If so, you
solved the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Aug 22, 2011 | DCS BGB30-BQR Grill
I bought a dcs fryer at a restaurant auction. I had it installed in my restaurant, and when I got it going flames were shooting out of the back. I had it looked at, but because there is no serial number...
The difference between Natural Gas Set Up and Propane Gas Set Up on Fryers are as follows:
Natural gas burner orifice has larger bore (#52) than Propane Gas burner orifice (#55 or #56).
Gas Valve's spring kit for natural gas has less tension (thinner) than Propane.
You have to order burner orifice ( the quantity depends on the number of burners your fryer has), pilot orifice and Gas Valve Spring Kit for Propane Gas if your fryer is set for Natural Gas or vice versa.
Regards.
Jun 22, 2011 | DCS Kitchen Appliances - Others
We inherited a Gas Grill DCS. Need a manual.
You may find one on line or at DCS site
Mar 14, 2010 | DCS BGB30-BQAR Gas Grill
Can't get even flame on burners
Natural gas and Propane operate at different pressures known as WATER COLUMN INCHES and require different jets to work properly.
If you have changed the jets ( installed in the correct direction) and are using a new LP regulator You should be good to go. If you are using the old Nat Gas regulator it just ain't a goin a work
Feb 15, 2010 | Grilling
I have two dean sr142gps fryers and am looking for an owners manual. I want to know how to adjust the flame onthe burners.
The only way to adjust the flame is by changing the orfices on the burner tube manifold. Dean is owned by Frymaster & you can contact their technical Dept @800-551-8633
Jul 19, 2009 | Kitchen Appliances - Others
Dcs 48" gas range igniter comes back when set on low/simmer
This is not a solution but something to think about for troubleshooting.
On the DCS there are two ports that feed gas to the burner.
One for high flame and one for simmer.
On the DCS if the flame is snuffed out on simmer it will automatically reignite.
So if the igniter will not shut off while on simmer, the sensor is bad and is trying to reignite the burner.
May 11, 2009 | DCS 24-24G-1 Gas Kitchen Range
DCS BGA27-BQ (NG) Grill Logo
241 people viewed this question
Top DCS Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
joel920368
Are you a DCS Grilling Expert? Answer questions, earn points and help others
