Question about Toshiba Satellite A135 Notebook
Replace cd/dvd for a135-s4677 - Toshiba Satellite A135 Notebook
  • 134 Answers
Simply get the cd/dvd rom.that simple
Posted on Jul 04, 2009
I have a to toshiba a135 s4677 and I can not get it to go on the Internet can I please get some assistance
turn off or rest your router, I prefer to unplug & plug, & restart your PC, that is the fix 90% of the time
Jun 02, 2015 | Toshiba Computers & Internet
I have a satellite A135-S4677 laptop and I cant get the microphone to work!!!! please help....
Goto Start-> Settings-> Control Panel click on sound and audio devices.Click on advanced button under device volume.
On the popup control click on options properties and click on recording if you cannot access that select the drop down above and click on input and then click on ok. Un mute the mic and if you have a recording volume slider , set it to the level you want. Now test by speaking into your mic and set recording volume.
Jan 15, 2011 | Toshiba Satellite A135-S4527 Notebook
My laptop monitor goes dim or blacks out. I replaced the LCD screen but no help. What is the problem? Toshiba A135 s4677 laptop
I have had similar issues and it turned out to be a battery issue. Please replace the battery with a compatible battery sold from an authorized reseller.
Good Luck,
NOLA Tech
Mar 01, 2010 | Computers & Internet
I have a toshiba satellite A135-S4677 it doesnt start at all i have it plug in and no light from the laptop just the light from the power cord please help
the adaptor may be out it may not be supplying power to the laptop power supply circuit
or
the power unit circuit in the notebook may be out
or
the motherboard may be down...
only tech shop can fix it...
Jan 21, 2010 | Toshiba Satellite A135-S4527 Notebook
Microphone issue with "Toshiba Satellite A135 4656" with XP
Most of the drivers can be found here:
http://il.computers.toshiba-europe.c...jsp?service=IL
Select: Notebook
Select: Satellite Promag-glass_10x10.gif
Select: Satellite Pro A Series
Select: Satillite Pro A200 (PSAE1)
Select: PSAE1
Select: Windows XP
Select : Search
This model has the same Chipset Drivers as the A135-S4677
You will need XP SP2 (NOT SP3)
The LINK will show you alot of drivers, but follow this order by make and version #
Chipset Utility: INTEL 7.1.0.1014
Display Driver: Intel 6.14.10.4833
LAN Driver: Realtek 5.664.205.2007
Wireless Driver : Atheros 5.2.0.125
Sound: Realtek 5.10.0.5464 (Next page)
Modem: You will have to select you region
Sep 26, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite A135-s4677 default passcodes
Hello, There is 3 things you can do.
1st the most easy thing to do if you have nothing important on it then do a complete system restore. by selecting the relevent key f10 f11. OR you could try pressing F8 before wndows starts to boot then from the new menu select recovery option from that menu the follow the on screen options
2nd if it can be done as an option in the restore menu then do a partial restore to a previous point that might remove the password.
3rd use another computer to download a password removal tool this uses the startup boot via a bootable dvd/cd it then uses its built in program to access the Microsoft password system then to either remove or change the password.
However if it is the bios you will need to short the cmos by taking it apart removing the battery or using the jumper to clear it. this WILL void any warranty though.
Sep 25, 2009 | Toshiba Satellite A135-S4527 Notebook
A135 Series on XP Microphone Wont Detect Sound
your laptop might have the microphone listed but it might just be a port to plug one in.thats the way mine is.
Aug 09, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshibba laptop a135-s2276 ,my mother bords smd chip does not work so display of screen does not appear
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
Oct 15, 2008 | Intel Motherboard
Toshiba A135-S2276 with a Hitachi GSA-T10N DVD/CD Drive.
The laser went to it´s maker. Problably you will have to replace the drive, but before you do that, try cleaning VERY GENTLY the laser lens with a 80/20 solution of water and alcohol. Close the drive and let it dry for a few minutes before inserting a disc. Sometimes it works.
Oct 11, 2008 | Toshiba Satellite A135-S2276 Notebook
HAVE A TOSHIBA SATELLITE A135-S4677 NOTEBOOK AND HAVE FORGOTTEN MY HDD1 INNER BIOS PASSWORD & NEED TO RESET IT IF POSSIBLE.
This works only for some models.
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back the mylar. there should be a set of solder pads labeled JOPEN1. Short the JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw. Hope this helps.
Feb 29, 2008 | Computers & Internet
Toshiba Satellite A135 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
