Question about Solar 15 Amp Murray Afci Circuit Breaker
I have 5 murray combo arc faults installed in a home and 3 trip consistently for no reason. i installed cutler hammer combo arc fault breakers and have to trips. is there a difference between manufacturers?
  • 2 more comments
  • joe_nicole_m Jul 04, 2009
    Thanks. I have tried this suggestion, with the same result. I have installed Cutler Hammer combo arc faults and they do not trip?? Just the Murray ones. However, it is a Murray panel and the inspector will only allow Murray breakers in it.
  • James Smith May 11, 2010
    I am curious if there are any GFCI outlets connected to any of the circuits that are powered by the arc faults in the panel.
  • Bob
    Bob May 11, 2010
    AFCI's have been a PITA ever since they came around. Are you able to read the Murray LED indicators? If so, how many and which led's are lit? Is this a service upgrade on an existing home or new construction? Taking one circuit at a time, remove the black, white, and equipment ground (bare) wires of each cable from their terminals. Make sure the bare wire isn't touching anything metal. Using an ohm meter, test between black to white, black to bare, and white to bare. There should be NO continuity between any of those wires.. Do that for all circuits concerned. Another thing to consider, if this an existing wiring system, is that since you are using combo afci's, you may have loose connections on the circuits that are arcing. In that case you will have to go to each outlet and inspect all the connections. If you have to do that, it's best just to go ahead and replace the devices while you're at it. Another possiblity is to go back to the store where you purchased the Murray panel and talk to the manager. Tell him/her that you want to return the POS Murray panel (regardless of the fact that's it's punched full of holes) and swap it for a Cutler-Hammer. If they balk at that, then tell them you want 5 Murray combo AFCI breakers that _work_. I know that would be a lot of work, but it will get your inspection.
  • Bob
    Bob May 11, 2010
    Remove the wire from one of the breakers that is tripping and (temporarily) connect it to an AFCI breaker that isn't tripping. If it trips that breaker, there is a problem with that circuit. AFCI circuits can be a real pain as it doesn't take much to trip them. Did the breakers that are tripping work OK at some time in the past, or are these newly installed circuits?
  • 760 Answers
The arc fault breaker must be made for the panel. Use of a breaker (any type of breaker) that is not either listed or classified for use in the panel is a code violation. Yes there are some differences between manufacturers. Compare specs. Make sure you installed the new breakers correctly, or they won't work at all anyway. Just because a breaker fits doesn't mean it's the right one for the panel.
Posted on Jul 04, 2010
I have a electrical problem in my 200 AMP murray braker box.It was put in around 1975.It looks like the 200 AMP main breaker is arcing.When the fridge starts the lights go dim..Will another braker work?
The best answer I can give is a new breaker might solve the problem.If the arcing has not damaged the bus bars where the main breaker is connected. Be sure to check to see that all connections are tightened properly. If you are using aluminum wire be sure to use a deoxidizing compound. Tighten the aluminum connections, wait a while, and recheck tightness.
Hope this helps.
. Bob
Nov 06, 2013 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Arc fault breaker trips when you turn florescent and can lights on
Sounds like something is wrong with the light check the wiring. Unhook the light and try ther breaker if breaker does not trip then problem is in the circuit.
Jul 24, 2011 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Is it normal for BR115AF breakers to feel warm to the touch (130 degrees f) with amped loads of .6 and below? This was found on a presale home inspection.
Nope, at .6 it should be at ambient temperature. I suggest powering down the panel and check for loose connections(which will also cause a rise in temp)
If you are not comfortable doing this then get a qualified electrician to check it out.
Jun 16, 2011 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Bought a Eaton Cutler Hammer Arc Fault 15 amp Single Pole circuit breaker for my old CH20 model Cutler Hammer CB Box (vintage about mid 1960s). CB package says "Use in Type CH" boxes. It...
I used to run into that being a service electrician all the time Smains! These problems can involve a little more legwork to figure out than some. The best advice that I can give you is, if at that age you can still find a part number on the breaker panel (they renamed them load centers to sound fancy lmao), if you can actually fine a legible one. Write it down and go to Eaton's website, then to load center. They have a parts number search that should take you right to your PANEL lol, and all the specs. I'm not there or if do it for you, hope this helps!!!
Aug 18, 2017 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Cutler Hammer 20 Arc Fault breaker for bedroom outlets will not reset after activating test switch.
The circuit breaker must be turned to the "off" position first from the middle position, and then to the "on" position. The cutler hammer arc breakers carry a lifetime warranty so if it will not reset you may want to contact the manufacture.
Oct 24, 2010 | Cutler Hammer BR120AF BREAKER CIRCUIT BR 1...
Our circuit breakers keep tripping. The house is only 12 months old and our electrician says the builder installed Cutler Hammer Combination type AFCI is the problem. Is there a problem with these being...
They can be defective, but usually not. It is usually something that is plugged in that will not operate on the arc fault circuit. Brush type motors are bad as they are actually arcing at times. Unplug all devices, and try to find the culprit. These are for your safety, and once you find the problem devices you should be fine.
Sep 09, 2010 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Can i use murray in a cutler hammer
You should only use a breaker that is listed for use with your panel. Use of a breaker that is not either listed or classified for use in the panel is a code violation. Check the breaker to see if it will fit your panel (probably not) Murry is now Siemens I believe, and Cuttler Hammer is Eaton. There was a Murry-Cuttler Hammer-Challenger connection for awhile, but just because it fits doesn't mean it's ok.
May 22, 2010 | Solar 15 Amp Murray Afci Circuit Breaker
I have a question
Sounds like the breakers are mis-wired. This is a common mistake with those kind of breakers. The white wire that is permanently attached to the breaker (usually coiled) connects to the neutral bar in the panel. Look closely on the breaker, you will see two terminals. The white (circuit) wire that goes out to load connects ONLY to the neutral terminal _on_ the breaker itself, _not_ to the neutral bar in the panel.
Dec 17, 2009 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
Feb 26, 2009 | Cutler Hammer 1 Pole 15 Amp Ground Fault
Solar 15 Amp Murray Afci Circuit Breaker Logo
312 people viewed this question
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
