Question about Hoover HCA391FFK Bottom Freezer Refrigerator
Fridge not working but freezer is working perfectly.It makes the usual humming sound after I switched it off and defrosted it but still the fridge didn't cool down.Any answers would be gratefully received. Thanks, Bor
  • 89 Answers
Try checking your evap fan motor if it is not running you will need to check to see if it is getting power if it is then you will need to replace the motor also check your settings make sure th freezer setting is not set over half way the freezer setting controls the air flow to the ref
Posted on Jul 03, 2009
Hotpoint ctx18ea fridge not cooling
Kimberley, try this:
First see any sign of ice build up in the freezer.
1. Switch off power from wall outlet.
2. Open the fridge door and freezer door and keep them open for atleast 5-6 hours. Salvage whatever food you can.
3. You may now see a puddle of water under the fridge. Clean the floor and inside of the fridge if water and other fluids visible .
4. Now re-connect power and set the recommended settings- usually at 4. Close doors.
5. Your fridge will be making a humming sound. Let it begin to cool.
Good luck
Apr 05, 2014 | GE Refrigerators
GE GTS22KHP refrigerator - fridge is warm, freezer seems cold and is making ice. When the fridge was getting warm, we checked the freezer and some of the food in the door of the freezer was starting to...
With 'no-frost' fridgerators, they enter a 'defrost' cycle that is supposed to elimnate any frost. There are a few suspect parts, but it should be 1 of 2 parts. The timer that controls when it enters the 'defrost' cycle is occuring too often, or more likely, there is a thermostat that overrides the timer once the temp on the cooling coils (not freezer) reaches, say 55 degrees and commands the freezer to resume cooling.... I bought a themostat off amazon for $26 and put it in and no longer have my ice tray frozen solid after prolonged defrosting. Google 'no-frost' fridge how it works...
Oct 24, 2011 | GE GTS22KHP Top Freezer Refrigerator
I have a 5 yr old side by side fridge. just a couple of days ago I noticed that temp. in the fridge was way too warm. Freezer is fine, but when I felt for any kind of cool air circulating into the fridge...
frost on the coils means the compressor is working and it is making "cold" if the cold isn't getting to the fridge side the fan the brings the cold air to the fridge side is ethier blocked off or not working. If you have a small thermomator use it to check the fridge side apx 38 to 40 degrees is the "food zone". the fan is usually not to expensive and often not that hard to change. there is a timer that defrosts the coils usually about once every 24 You may see a small knob on the defrost timer. watch its position over several hours and you should see it move position. if it doesn't move then the defrost timer is faulty. the most expensive part of the system is the compressor and it sounds like that part of your system still functions. If the freezer is getting plenty cold but the fridge part is not cooling off you have an air flow problem. It is not uncommon for these fans to make noise and then fail altogether.
Apr 21, 2011 | KitchenAid KSCS25FKSS Side by Side...
Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Mar 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Fridge don't work after defrosting session
It depends on weather or not you damaged it during the defrost. Most fridges' are self defrosting. Look at the coils behind the back cover inside the freezer. They should be covered in a light frost if the compressor is working right. Or Is the fan in the freezer running. It has to blow the cold air around the freezer and to the fridge side. It may cut off when the door is open so hold the door switch in to check. The humming in the freezer could be the fan trying to run but can't because of a defective fan or being blocked by somthing.
Sep 02, 2009 | Candy CPCA270FFK Bottom Freezer...
My freezer is working perfectly but the fridge is not
The channel in the back were the cool air comes down from the freezer to the fridge may be iced up. Try defrosting the fridge/freezer for much longer than usual, all day if necessary.
Aug 30, 2009 | LG LRTP1231W Top Freezer Refrigerator
GC2224gek admiral freezer keeps defrosting and the food thaws. The fridge is working. Switch it off for a day and fridge, freezer and ice maker works. After a few days it starts defrosting and I noticed it...
I believe your defrost control board is defective part number 0165748 You can visit my site below and enter the part number or the model number GC2224GEK in the search feature. We also offer free help, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Lights on but fridge not working on Fisher and Paykel N500B
There could be a few reason 1 you may have a faulty temp control switch try taping it to see if it kicks on.If that does not work remove the compressor start switch shake it to hear any noise like pieces burnt in it.If not try advancing your defrost timer to see it kicks on also.If those do not work you may have an elecrical problem.
Jan 18, 2009 | Whirlpool ED2GHEXN Side by Side...
Oil leaking out from under freezer side.
That oil is probably compressor oil. If the compressor leaks, you need a new fridge. Sometimes they only leak when they're charged up. That would explain the other symptoms.
Oct 16, 2017 | Frigidaire FRS26H5AS Side by Side...
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Hoover HCA391FFK Bottom Freezer Refrigerator Logo
241 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
