Aspire Acer (I think)
SOURCE: laptops
Try the solution suggested by kriswauters. Could be a motherboard problem but it could also be a bad keyboard. I would certainly invest in a new keyboard and see if that corrects your problem. Laptop keyboards are fairly inexpensive.
SOURCE: Acer Aspire 4720 PC Notebook doesn,t start in the evening hours
All drivers for Acer Aspire 4720Z model can be downloaded from ftp server of europe.acer.com site or from the link of acer.co.in
Due to resemblence of motherboard of Acer Travel Mate 6292, the drivers for this model & 4720Z are the same.
This information is given to me from Acer Service Centre .
you can sms them with serial no. along the problem. they will revert to u in 1 hr. 100% good service.
you can contact me at [email protected]
Acer SMS centre for cust care: 09901676677
Arun Kanojia
Pune
SOURCE: acer aspire 4720z
There are multiple problems that could be causing this. The most likely problem is spyware or a virus has infected your system. First off, you didn't mention your OS, but apparently it was shipped with Vista, so I'm going under the assumption that that is what you're running.
First thing to do is try this:
1) Open the start menu.
2) In the place where you can type, type "msconfig" without the quotes and press enter.
3) In the box that opens up (System Configuration) click on the "Startup" tab.
4) In startup UNCHECK EVERYTHING then press "OK"
5) Restart your computer.
If the system starts back up and starts responding much better, chances are something that was loading up in your startup menu was causing the issue (most likely spyware) in which case download, install and run both of these:
Ad-Aware: http://www.lavasoft.com/single/trialpay.php (You can choose "free" version)
Spybot Search and Destroy: http://www.safer-networking.org/en/download/ (100% Free)
If you're still having problems, you can try doing a "System Restore" by doing this:
(Warning, this will revert your system back to an earlier date, so make sure you have backups of the software you've installed since the computer started having problems)
1) Click "start" and type "System Restore" (without the quotes) and press enter.
2) On the window that comes up choose "Choose a different restore point" and click Next.
3) Make sure you put a checkmark in "Show restore points older then 5 days" and look for one from before your problem started happening. Then press next.
4) Just press finish. It should restart your computer and start doing the system restore. If it doesn't restart your computer.
After the restore is finished, check to see, is everything working fine? If it is, SUPER, if not you'll have to go a little more extreme.
If the system is still problematic, you'll have to do a full system recovery. Back up ALL the data you have on your system that you don't want to lose (documents, pictures, mp3's, bookmarks) first before performing this task as it will wipe your hard drive and everything on it.
When you turn on the computer you want to get into your system recovery. It's usually either F10 or F11 (Consult your documentation if that's not it) just follow the prompts until the system is restored.
If THAT doesn't work, you've got a hard drive that is about to fail, or ram that has failed in your system and you'll have to bring it in for warranty issues.
HOPE THIS HELPS!
SOURCE: i've been trying to restore my acer aspire one zg5
Follow etaf's instructions above, if you cannot enter the Acer recovery utility try this...
Do not press and hold Alt + F10. Do it like this... From the Acer splash screen press and hold the Alt key while constantly pecking the F10 key.
However, you want to save all of your photos, favorites folder, music etc. on an external disk or flash drive before entering the Acer restore utility above. Anything that DID NOT come pre-installed on your netbook will be lost. Once restored, always, always, always back up your system with an external disk or flash drive as you go, meaning that as you add legitimate software and personal files to your PC and your PC works normally, back it up. It's cheap and the next time this happens you can enter plug in your flash or disk run the restore, and have EVERYTHING back including the stuff that did not come on your system when you bought it.
