Question about Acer Aspire 5520-5908 Notebook
My acer 5520 will not charge and i dont know if it is the charg
My acer 5520 will not power up anymore and when i plug it in the power and charging lights alternate red and yellow lights. I can sometimes remove the battery and get it one good charge, but then problem happens again. Dont know if it is the battery or charger. Once I can power it is works great but this problem is getting progressively worse.
I have a acer 5741. I have tried many times to charge it but it wont charge no matter how long i leave it plugged in. It is stuck on 10%. When I plug it in it says its charging but nothing actually...
1. Unplug AC adapter. Shutdown
2. Remove battery, Connect AC Adapter
3. Start windows7. Remove Microsoft ACPI-Compliant Control Method Battery under device manager , battery
4. Shutdown, Remove AC Adapter, Install battery, Reattach AC Adapter.
5. Power up -
Now Plugged in and Charging.
Aug 04, 2011 | Acer Aspire 5520-5908 Notebook
My Aspire 5520-5043 began showing trouble to start: no power ligh
thats mean the charging system is faulty and sometimes there are breakages at the edge of the power cable where the pin is.try another power cable if it shows the same signal then the fault is on the laptop board.
Aug 02, 2010 | Acer Computers & Internet
Won't turn on
Try to do the following . . . removed the battery then plug the power adapter to the laptop. If you are not getting a green light on this that means there's something wrong with your power adapter.
Try also plugging to a different power socket. We'll just make sure that the power source is not the issue.
If still you are not having success on this it is advisable to visit the nearest acer shop and let them check the laptop. The issue might be internal.
Hope this helps . . .
Apr 03, 2010 | Acer TravelMate 5520 Notebook
Acer Aspire 5520 Power Problems! :(
1. Actually the problem is not with the charger / adapter!
2. The plug-in port / jack of the laptop has become loose.
3. Don't try to work out the charging by adjusting the adapter plug with different angles. It will just damage the plug-in port (the wire inside the port will become loose and unaligned)!
4. Contact the Acer authorised service center for repair / replacement of that plug-in port / jack in the laptop! It'll just cost some bucks!
please rate this advice if it helps....tc! :)
Jan 14, 2010 | Acer Aspire 5520-5156 Laptop
My acer aspire 5520 will not start. the battery light is on and is red.have the ac cord in and it still will not turn on. it came on once for about 20 sec. but long so i could boot in safe mode. please...
just conncet the main power and keep as it is for 10 - 20 minutes let the battery get charged. latre on try to swicth on the laptop .if you still facing the problem then remove the battery from laptop and directly switch on main power.
Nov 27, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire 5520 wont power up.. no charging light when connected to mains
Try another charger. If it turns on and chargers the unit you are currently using needs to be replaced. Do not leave your charger plugged in after charging your battery as this will shorten its life.
Oct 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
I HAVE A ASPIRE 5520 IT WONT START THE FAN STARTS AND THE DVD BUT IT JUST KEEPS ON LOPPING
I had the same problem but what you can do is...
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
  8. If its not the batery or AC adapter you might have to send it to Texas, just go to www.Acer.com
Jun 14, 2009 | Acer Aspire One PC Notebook
Laptop Computer wont power up
i unplug mine and then wait an hour plug it in and it starts up sometimes he fan has to charge
Apr 10, 2008 | Acer Aspire 5500 5570-2609 Laptop
How to get Service manual for 5520
I have the 5000 series service manuals, please email me at
ChrisLemke@LBSEnterprise.com and I will send them to you.
Feb 09, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 5520-5908 Notebook Logo
419 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
