Question about Honda Pressure Washer PSI 3000
Goes for awhile at high pressure then just cuts off
  • firehead May 11, 2010
    Does it shut down completely or do you just loose pressure?
  • 32 Answers
Does the engine cut off or the pump cuts off.
the honda engines has a oil alert on the side, check the oil level.
check the nozzle in lance for over pressuring
Posted on Jul 04, 2009
Where is the low pressure cycling switch?
Low pressure rarely goes bad, it is always on. It works the opposite of the high pressure switch. When the pressure gets to high on the low side, the switch will cut off the compressor. Low switch is usually by the compressor or mounted in the compressor. What's your A/C not doing.
Apr 30, 2016 | 2001 Chevrolet Malibu
I was told by A/C guy I have a short somewhere to the high pressure switch. something is not kicking on the compressor. another mechanic said I need a new computer. what do you think
go with the ac guy
there are systems that prevent the ac compressor working
high pressure switch which cuts the ac clutch if the head pressure goes too high
low pressure switch which cuts power to the ac compressor if there
is no gas in the system
climate control systems which cut power when the ac is not required
fuses to the ac system
get a better explanation or seek advice from other ac mechanics
May 01, 2015 | Cars & Trucks
02 buick lesabre starts up great cuts off after awhile or 5-8 seconds after driving. Replaced f/pump
check your fuel pump pressure sometimes after market parts are faulty
Apr 11, 2014 | Cars & Trucks
2007 honda accord diesel cuts out then takes ages to start,also goes into limp mode,states fuel rail pressure on diagnostic,had injectors tested,had new high pressure fuel pump,had new filter and hous
replace the high pressure pump with a known good normal pressure pump and see if it fixes the problem. Fuel systems are built around a pump supplying enough fuel to maintain operating pressure . There is a pressure regulator that keeps the pressure steady and a pressure sensor switch that turns the pump on and off as required . Pressure can only be generated when the fuel supplied exceeds the flow requirements and all units are built to suit the requirements of the system. By adding a high pressure pump that means that there is far more fuel than is required and it is possible that the pressure regulator is incapable of unloading sufficient fuel to accommodate it . Therefore the injectors will be getting more fuel than required and so the whole system goes to pot.
Mar 28, 2014 | 1992 Honda Accord
I need to find the ac cycling switch on 2002 neon
There should be a low pressure and a high pressure switch on the lines or the compressor. The low switch cuts power to the compressor if freon or pressure is low, high cuts power if pressure in the system goes over 300 psi.
Jul 21, 2012 | Dodge Neon Cars & Trucks
COMPRESSOR ON & OFF FREON LEVEL OK
You need to hook up a gauge and read the pressures on the low and high side. It will cut out if the pressure drops too low or goes too high. If it was properly evacuated and charged I would assume it is probably high pressure cut out which would be indicative of a plugged orifice tube or restriction in the system (line, condenser, evaporator.
Jul 06, 2011 | Chevrolet Colorado Cars & Trucks
Is there a way to test the compressor for high pressure
If you are doubting the compressor is bad,remove the lines,after the ac system is discharged,and blow threw the condenser to see if it is stopped up,and go ahead and remove the orifice tube and replace it,you will have to do these things anyway if you replace the ac compressor.Rate please if this was helpful,thank you.
Jul 21, 2010 | 2001 Pontiac Montana
Oil guage drops then goes to high range
sounds like your sending unit needs to be replaced cheap fix and if your oil pump losses all its pressure you will begin to hear knocking coming from your motor from the top under the heads.
May 27, 2010 | 1991 Buick Park Avenue
Honda gas power pressure washer runs for awhile then cuts off.
did you pour all of the old gas out before you started to use it. Sometimes condensation builds up in gas tank when stored. You need to dump old gas an put in new gas.
Jul 27, 2009 | Honda Karcher G4000RH Pressure Washer
Same problem - flaky A/C 96 deville concours
too much freon is the same as not enough,you should buy a set of gauges to fill your system.
Jul 25, 2009 | 1996 Cadillac DeVille
Honda Pressure Washer PSI 3000 Logo
273 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
