Question about Alpine MRP-M450 Car Audio Amplifier
Wheres the power.. No bump
IT puts sound though but it doesnt not seem to put enough power into the subs "12's" to bump them..
  • Joel Friedenberg May 11, 2010
    The Alpine MRP-M450 Car... amp is a MONO amp. How many Subs do you have hooked up to it? It will put out 400 watts @2ohms/one sub.
  • Jorge Majano May 11, 2010
    what kind of subs do you have? like what is the wattage?
    Novelist:
  • 133 Answers
It might be that your subs are too powerful for the amp, check the model of the sub or subs online and check out how many watts they can take, because you might need to upgrade your amp or downgrade your subs
Posted on Jul 06, 2009
  • Jorge Majano Jul 06, 2009
    either that, or the wires directly to the subs are too thin, i know the wires need to be 8 gauge wires, so it might be that too, hope it helps. Goodluck
How do I hook up my interfire ib2900c amp correctly??...hooked up 2 dvc 2 ohm 12" subs ...to 2ohm stereo load..but all I get is loud blurring out sound forcing me to off..what do I do??
If the subs you have are 2 ohm DVCs, that usually means each voice coil is 2 ohms. Putting the DVCs in parallel will make the sub 1 ohm, which is beyond the capability of the amp (which is only stable down to 2 ohms per channel). Putting each subs DVCs in series (for a total of 4 ohms per channel) will at least allow the amp to operate properly, even though you will not be able to maximize the output power.
http://www.interfireaudio.com/download/interfire_catalog_2009.pdf
Oct 06, 2015 | Ohm Car Audio & Video
I hooked up 1 10" type r to my 600w sony xplode
How many ohms is the speaker? You have the amp bridged going into the sub? You have the negative of one side hooked up to the negative and the positive on the other side hooked up to the positive?
It says that it is bridgable at 4 ohms. What about the input? Set your stereo about half way up. Then turn your amps gain up slowly until it is where you want to listen to it normally. Not to loud. Then when you turn it up it isn't too much.
But it sounds like you have way too much power for one speaker. Especially a ten. It takes two tens to equal one 12.
Dec 17, 2010 | Sony Car Audio & Video
Subwoofer loudness
Do you have enough amp to power the subs, sounds like the coils are heating up and shutting down. Twice the amp for the wattage of the speaker as in 100watt sub 200 watt amp supply and so on.. 1000 watt sub would need at least 1500 watt continuous out put
Mar 09, 2010 | Car Audio & Video
I have a 12 kicker sub and a 600 wt power acoustic
there is a volume on the amp try that and the settings on your deck allow you to adjust your subs
Jan 15, 2010 | Kicker Car Audio & Video
Boss 2600 watt amp bumps untile i turn up past like 12
subs may not be abel to handel the amps out put or vicea versa . make sure subs and amps ohm specs are compatible (2 ohm subs ) 2 ohms stabel amp
Jan 03, 2010 | Car Audio & Video
I need help tring to put 4 mtx subs in my car
depends on the car.
suvs;
get a box made for 4, the fire towars the headliner or the floor but work. or you can make a U box and fit 4.
to fit 6,
4 in the trunk and if ur back seats sit high enough 1 under each seat.
of a custom box to hold 2 in the front, 2 on top and 1 on each end. = 6... all in one box. loose sound quality but would work.
Jan 29, 2009 | Alpine MRD-M1000 Car Audio Amplifier
Amp problem
depends on what subs you are using that amp puts out a max rms of 150 watts x 2 no kicker brand sub will run of that low of power. the fading you are hearing sounds like the amp is being overdriven and it is hard clipping because it doesnt have enough power for the subs. that amp is designed for mids and highs.
Jan 09, 2009 | Kicker 04KX350.4 Car Audio Amplifier
Problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
Wiring
In all reality, that amp is probably a bit small for those two subs. To maximize the power from the amp to the subs, make sure:
  • The dual voice coils of each sub are in parallel (+'s together, -'s together). This makes each sub 2 ohms.
  • Connect the subs in series (+ to -). This makes the combination of subs together 4 ohms.
  • Bridge the 2 channels of the amp to the subs in series (see above).
This will put somewhere between 150-200W to each sub.
Keep in mind, though, that depending on the music type and location in the vehicle, the type and size of the sub box is going to make almost as much difference as how much power is on the subs. Sealed boxes are usually small and have a nice flat response, but tend to need more power to sound louder. Ported and bandpass boxes are larger and aren't as flat of a response, but have nice loud peak at a certain frequency.
Let me know if you need any more help!
Mar 19, 2008 | Lanzar Vibe 218 Car Audio Amplifier
Amp protection problem
I run one sub on my Kenwood Amp also. It does over heat also. My conclusion is that we are both trying to push that one sub too hard and the amp is having to work really hard to make that sub do what we are asking. Also, not having enough power or a good ground will cause it to over heat. I am going to go with the voice coils are heating up though.
Sep 16, 2006 | Kenwood KAC-9102D Car Audio Amplifier
Alpine MRP-M450 Car Audio Amplifier Logo
140 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
