I have a 1994 f 350 turbo diesel IDI when I try to start it the starter gets hot and the power gets hot
Don't just keep cranking if it don't start right away' Give the starter a break. It's getting hot because you just keep cranking on it. Any vehicle diesel has glow plugs to heat the fuel chamber to make it start fast. Be sure you are making use of the glow plugs and it will start fast. If your glow plugs are not working, find out why. Could be just the glow plug relay or connection to it. Or possibly the glow plugs are burned out. Either way, you HAVE to have glow plugs in use on a diesel upon initial start up till it's warmed up. Then will start without them. Most are automated system. You just have to wait till the glow plug light goes out to start cranking on it. I hope this helps you to more understand the workings of a diesel cold start system.
