TV won't stop changing channels
Olevia LCD Tv won't stop changing channels. There are no stuck buttons and it happens when i use the remote or when i use the buttons on the TV unit itself. Volume and mute does the same thing--nonstop volume increase or decrease with one touch of the volume button. What is going on?
    President:
  • 1,779 Answers
Main board needs replaced !
Posted on Jul 03, 2009
A late response, but might prove useful to somebody:
I recently had similar symptoms. Turned out to be the a controller for my blu-ray player, which otherwise has no effect on the television - the TV shows no signs it recognises any button push on that remote. However, one of the remote's buttons was stuck down, and somehow the signal it was firing into the room was confusing the television in this case. Unsticking the button restored normal function from the TV remote and front panel controls.
Posted on Jan 12, 2012
    Problem Solver:
  • 5 Answers
Get a new tv
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Olevia tv won't auto program you can punch in numbers but you cannot channel up it goes into mute
problem with keyboard on set front or side===likely defective switches under the plastic buttons.
May 13, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
I have Dish Network and remote #1 and 2...the TV for Remote #2 has now changed but the remote will not work...I replaced it with an Olevia Flat Screen (used one) 32in LCDHDTV Model 432-S12 but cannot...
If this hasn't been resolved, I do have some steps that will help you out. The link below will walk you through a power scan, which will program the remote to the tv. At that point, you will be able to change the channels on the tv with the remote.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Jul 14, 2010 | Olevia LT37HVS 37 in. LCD HDTV
My Olevia TV will not change channels using the remote or buttons on the TV. When I push the channel up or down button, the tv mutes. It will change to 1 channel using the return button. I have tried...
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
Apr 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
AUTO PROGRAMMING T.V.
Your TV is in Showroom Mode - to change:
Menu>Picture>Mode>Power up>Home
Then go back and autosearch channels.
Jan 10, 2008 | Olevia LT42HVi 42 in. LCD Television
Program remote for olevia television
I have a olevia tv with olevia remote, I have to type in the number to change the channel. what do i need to do to fix the problem? So i can use the tv channel changer.
Dec 23, 2007 | Bose Cinemate Digital Home Theater System...
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
406 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
