How to program a remote control prostart in a jetta 91
I can not program remot control from prostart in a jetta 91
  • biere Dec 29, 2007
    My '97 Civic (no power locks / no keyless start or anything extra) has a prostart remote starter. It doesn't work after about 6 years of service. Do they just commonly die after that time or is it my remote? I changed batteries, and I will say the buttons work if I press firmly. Sometimes red light on remote won't shine so I press again, and they work.
    I suspect maybe the programming needs to be re-done so how can I do this? If this won't work, at least I know my remote is the problem and can maybe get a new one, instead of a whole new installation.
    My button switch is a little loose too. Tried to tighten and sanded to clean around where it meets metal on car. Seems to make ok contact. Do the button switches commonly go?
    When I turn off and on the valet switch under dash, I get beeps and lights as I should. Does that mean the unit itself is still good?
    Help please and thank you. I don't want to get a new one at this stage of the car's life if not necessary.
  • Nhlpa Nov 11, 2008
    i have a new 2 button remote starter from canadian tire pro start i disconnected battery on car and lost everything how i re program? thanks Barry
  • 72 Answers
Sounds as if the device is now out of the warrenty by now. any Devices like this are common to break down. Im surprised you got 6 years out of the bugger. the companys want you to buy new ones. you can try checking the prostart website fora replacement remote, but the cheapest way out is to goto a wall mart and get a new remote start.
Posted on Feb 16, 2008
Programming a remote for prostart 3460 tw
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Nov 21, 2014 | Televison & Video
I have prostart 3 way new installed into 1995 f250diesel can't get remotes to conect to the prostart brain box
Verify batteries are installed and installed correctly in the remotes. Examine the batteries and the battery holders on the remotes for "shipping isolators", pieces of plastic film or tape that insulate the batteries from the battery contact points. Verify the batteries are fully charged with a volt meter. Beyond these basic check points, contact prostart support.
Jan 19, 2014 | Cars & Trucks
How do I reprogram Prostart remote starter/car alarm after replacing car battery?
Try turning the Prostart off, then on with the little toggle switch. Check that the hood pin switch is working as it should
Dec 03, 2013 | Cars & Trucks
Check its main digital board. It might need replacement.
May 03, 2013 | Televison & Video
I installed prostart remote starter in 2002 Sonoma,used xpresskit bypass module to bypass passlock 2, truck started with remote ,now won;t start with remote,have to reset and start with truck key
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground.
Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
Oct 01, 2012 | Vehicle Parts & Accessories
Mi car no stop alarm his jeeta 99
You may have to reprogram the remote. Follow these steps CAREFULLY;
Remote Control Programming (1997 ON)
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
Nov 20, 2010 | 1999 Volkswagen Jetta
I have new keys for my 1999 vw jetta tdi, but i don't have the remote to program the new keys. how can i go about doing this since there is no vw dealers in belize
"small"problem.If you don.t have remote control the keys can be programed only with diagnostic equipment.There is another procedure but you need of wiring diagram of the immobiliser to cut off the wire.Means - ignore for ever the immobiliser.Not safety in Belize.Just take your decision.
May 13, 2010 | 1999 Volkswagen Jetta
How do you program my remote on my prostart as the battery died and i replaced and still doesnt work?
press the hood pin switch down for 4 sec, release then press and release again, turn your key on and then off and hold the lock button down on the prostart rmote until the unit clicks 5 time then release
Feb 27, 2010 | Samsung Phone PDCSLCD12B
I can't lock the car using the remote key. the light flashes on the key but does not lock the doors
try reprograming the remote, if that doesn't work u may need a new remote these are the factory instructions.
1. Switch ignition on with a key (don’t start the engine!); leave key in the ignition.
2. Mechanically lock vehicle at left front door, using second key.
3. On remote unit, press "Open" button once. A short horn signal will sound.
he "Open" button is pressed once for programming the first, or a single,
remote unit.
�� When programming additional remote units for the second, third or fourth
memory addresses, press the "Open" button two, three or four times, in
one-second intervals.
�� Example: press the "Open" button once, wait 1 second, then press once
again to program the second remote unit.
�� After 6 seconds, press "Open" button once to activate the coding ocess.
4. The remote unit will now be coded, and it can be used to unlock the central
locking system. Switch ignition off.
The key must be removed from the ignition before the remote unit can be used to lock
the vehicle.The coding process can be repeated up to 4 times for additional remote units.
In between each remote unit coding, the ignition must be switched off.
Apr 10, 2009 | 2004 Volkswagen Jetta
Computers & Internet Logo
1,230 people viewed this question
David Payne
David Payne
