Question about SMC Barricade 7004 Router
Port SMC100 Registry Problem
I keep getting an error message that says "Port SMC100 Registry Retry", that comes up every 15 seconds. How do I stop this?
What I need help with is logging into Facebook from my iPad. Can you help me troubleshoot?
get iobit mobile care, Advanced Mobile Care Android Security for Mobile IObit
run it and try again,if not then delete safari and facebook and download safari,update it then download facebook app.
Jun 20, 2015 | Facebook Social Network
Lanier 5227 scanner error
Eenter in the service mode press yellow key - 107 - red key(stop) keep press for 5 seconds,enter in the SP mode open the front door,turn OFF the main switch,wait 15 seconds close the front door,turn ON the power switch.
Jan 22, 2012 | Lanier Office Equipment & Supplies
I have a problem in downloading yahoo messenger when i start download the following massage come "yahoo messenger is unable to download files needed for installation please firewell setting and...
1.Clean up junk filses.
2.Clean up cookies.
3.Clean up registry errors.
4.Speedup the system.
5.Speedup the startup.
Use Reginout to fix it
Feb 16, 2011 | Yahoo Messenger
System is wont boot
Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
Heres how to fix the issue
Download the software fix by clicking here.
Launch it after finishing the installation.
Click “Scan Now” button
Click “Repair Problems” button and fix 0x0000008e.
May 21, 2010 | HP Pavilion dv6000z Notebook
Try to turn on webcam,it comes on momentarily and then i get an on- screen message saying the cam is used in another application, and to shut down other applicaton and retry,
Webcam software has a habit of remaining hooked up to any previous application it was used in.
When you get this message re-boot the webcam software by unplugging it from the USB port for a few seconds.
Apr 19, 2010 | Logitech Quickcam Chat Webcam
I keep getting an internal iss with yahoo
Your computer has registry problems.It is very easy to repair yahoo messenger internal error. you just need to do 3 things:
1: Download a registry cleaner and install it.
2: Open the registry cleaner and scan you computer for free.
3: Click fix button and you done.
Download the top yahoo messenger internal error repair tool here:http://www.fixerroreasy.com/ttfix-yahoo_…
Source(s):
Mar 13, 2010 | Yahoo Messenger
USB port malfunction
CHECK THE RATING ON YOUR POWER SUPPLY BECAUSE SOME LAPTOPS WILL REGISTER THE POWER CONNECTION PORT AS A USB PORT AND IF YOUR POWER SUPPLY VOLTAGE IS TO HIGH FOR THE COMPUTER IT WILL REGISTER IT AS SUCH, "HUB-PORT" IS SHORT FOR MAINBOARD PORT ON SOME DELLS. UNPLUG YOUR POWER SUPPLY AND CHECK THE RATING ON IT COMPARED TO THE DELLS INPUT VOLTAGE, THE INFORMATION IS NEXT TO YOUR SERIAL NUMBERS AND LABELS ON BOTH PEICES KEEP ME POSTED... JON-T
Dec 07, 2008 | Dell Inspiron 8600 Notebook
SYSTEM ERROR
1) if you have nothing in a USB port you will need to set bios
Try removing M/board battery for 2 to 3 hours some people say less then replace it most times it should set BIOS back to default
also check setup of hard disks master slave etc
Last resort with 15 seconds you should be able to see
press ?? key to access BIOS next boot keep pressing key see if that works
Aug 10, 2008 | ASUS M2N-MX Motherboard
PEN DRIVE ERROR
sounds liek a corupt upper or lower filter for cdrom devices also in usb section of registry.
prety much.. remove upper and lower filters and retry. or u got acess denied to system registry sections.
Jul 14, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Trouble installing HP officejet 5610 all-in-one
slbcsp.dll - this registry does not exist
sccbase.dll - this registry does not exist
gpkcsp.dll - this registry does not exist
Enum - installer can not access
Oct 22, 2007 | HP Officejet 5610 All-In-One InkJet...
SMC Barricade 7004 Router Logo
133 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
