Question about Whirlpool Dryers
No heat,but the drier turns on. Hal - Whirlpool Dryers
  • 253 Answers
Probable broken heater element. you can call a repair service or pick up a new element at a retail a/c appliance store using the make and model number from inside the door and have a neighbor/friend/ you trust fix it with basic tools.
Posted on Jul 04, 2009
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Drier turns but no heat (electric drier)
dsd
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 30, 2010 | Maytag Dryers
Dryer taking to long to dry cloths, all vents are clear
sometimes a element that heats the dryer breaks giving it only power till were it broke /then will cause no or very little heat these run about 30-34$ depending on what type of brand of dryer you have
Apr 10, 2010 | Maytag PYE2300AY Electric Dryer
Td 4212 w Drier is not heating
Check if it still turns but no heat. If it's a kenmore or whirlpool, it's like a fuse in back of dryer. I would need mor info if it's not these models
Jul 28, 2009 | Zanussi TD4212W Electric Dryer
Drier shuts off
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer'circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
No heat
make sure the drier vent is cleaned out of all the lint including under your filter screen in the drier all through the drier hose and out the vent to the outdoors
Apr 23, 2009 | GE Profile Prodigy DPSR513GA Dryer
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Roper Drier no heat and continuous run for two hours
Your drier heating elements operates on 220 voltage, the drum and clock operate on 110, so you either have a blown fuse in one side of the fuse box ( easy fix )some time the circuit breaker will just need to be reset by turning it off and back on, or your heating elemant has opened up and will be more expences to fix, or it could just be a wire end has burned off. unplug plug from outlet remove back from drier and have a look see, and if bychance you have forgotten to clean your link trap if could be a high temp safety that has open and sometimes can be reset by pushing the reset button, all this is inside the back of the drier, if after that it may be time to call your friendly repair shop
Oct 20, 2008 | Roper REX4634KQ Electric Dryer
Maytag Drier, doesn't turn, doesn't heat, but dings.
hi thanks for the question i would check the power coming to the dryer it looks like its only getting 110 check that the appliance doc
Sep 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
42 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
