REPLACED LAMP TV WONT COME ON - Televison & Video
  • 668 Answers
Be sure to check that the Lamp door is secured properly. Especially if the Lamp you replaced was bad.
Posted on Jul 04, 2009
Tv wont turn on Red standby/temp light and green lamp light are both blinking
The tv projection lamp been inside the tv like 1 1/2 or 2 years already,used tv every day like 4 or 5 hours a daily?The Lamp life are ended.Time to replaced the tv projection Lamp.
Dec 20, 2010 | Samsung HL50A650 50 in. TV
Tv wont turn on
The lamp life span is over,need a new projection lamp replacement.This tv lamp has not been replaced at least 1 1/2 or 2 years?The tv lamp in the tv now,tv on an used at least 4 or 5 hours a day too.
Jun 29, 2010 | Hitachi 42V710 42" Rear Projection HDTV
Lamp burned out so I replaced the lamp with a new
make sure the lamp is fully inserted and making good connection. a lot of people will forget to close the door, the tv will not function with the door open. close the door fully. unplug the tv for 2 minutes and then plug in and let it boot up for 30 seconds before you push the power button. toshiba is notorious for malfunctioning if you start hitting buttons right after you plug it back in, make sure you wait.
if this still wont fix your issue, look for the flashing leds on the front of the set. they will eventually give you an error code to go with. the tv can take up to 1 minute to come on and will try 7 times before spitting out an error.
May 21, 2010 | Toshiba TheaterWide 46HM94 46" Rear...
Tv not turning on
Ur tv,projection lamp been use alot about 2 years or more?The lamp must replaced the lamp life span it over.
Apr 05, 2010 | Hitachi 60V500 60" Rear Projection...
Viviteck 56''in.HDTV DLP TV. replaced with a new lamp bulb since I replaced this the tv wont come on only the sound for about 5 seconds then tv is silent again. any tips, Please.
The first thing to check on any TV that has a replaceable lamp is to make sure the lamp door is back on and seated correctly. You also need to make sure that the lamp is seated all the way in. The lamp door and in most cases the lamps have saftey switches they have to activate for the TV to work normal.
Nov 17, 2009 | Vivitek V37655 56" DLP TV
Wont turn on and lamp has been replaced.
You most likely have to reset the lamp timer. If it gets maxed out it will not turn on till it is reset. Check your manual to see how to reset.
Sep 12, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Replace bulb tv wont turn on
make sure the lamp and lamp door are seated properly. does it blink any codes. 3 blinks is lamp or lamp door not seated properly
Jun 25, 2009 | Sony KDS-60A2020 60" HDTV
Tv not turning on
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
Mar 19, 2009 | JVC HD-56G657 Television
I have replaced the lamp.Now the lamp wont come on and tv shutts
Did you replace the lamp cover after replacing the lamp? Make sure the cover is properly installed.
Jan 21, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Samsung HLP5063W Tv
while replacing the color wheel you know you see two cords running from it the blue/white cord and that copper cord. if you replaced both the color wheel and lamp, then it could be that copper cord just switch it around i did that and now my tv works
Jul 15, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
