Question about Sony KP-65WS500 65" Rear Projection Television
Hi, i'm not sure my sony kp65sw500 is hd tv or not, can you let me know and explain how to watch with my roof attenna, thanks.
  • giangtran74 Jul 03, 2009
    Thanks for you reply, but as I read online all about:
    Hi-Scan 1080i? Display Sony?s Hi-Scan1080i? TV?s accept the full 1080 interlaced scanning lines (1080i) or 720 progressive scan (720p) from an external HDTV receiver or a compatible high definition digital satellite receiver. It also accepts 480 progressive (480p) scanning lines from compatible DVD video sources.
    DVI-HDTV Interface (Digital Visual Interface) Has been added for the latest generation in high definition television connec- tivity. A single wire delivers a full digital uncompressed HD signal that can be received from any DVI set top box.
    What is it really meant? the highest it get is 480 only? is it worth it for me to buy the HD Decoder or should I just get the Gov. HD converter thing to watch local channel since it still in good condition. Thank you.
    President:
  • Sony Master
  • 1,779 Answers
You will have to get a good converter box with rgb outputs. The most your set can do is 480p anyway.
Posted on Jul 03, 2009
  • Jim Krause Jul 09, 2009
    I would just get the HD converter till your ready for a new set.
I got a sony bravia kdl46nx800 led tv and for some reason, there is a green line on the right edge of the screen on certain HD channels and not on regular channels when i watch the shows. it is a common...
Hi, I can't say I've ever seen that happen with that TV before so I'd say it definitely isn't common. I'm pretty sure it's the signal from the HD channels, I'd suggest talking to your cable service provider.
May 14, 2011 | Sony BRAVIA NX800 KDL46NX800 46 in. HDTV
Hello, I have a Sony KV-36XBR450 36" TV, and heard that it was "HD" ready but needed an upgrade. at this point I would like to know it that upgrade is still available and if so does, does...
Your KV36XBR450 is HD ready which means that you will need a set top box to receive the HD signal. Comcast will provide this for you naturally at an additional expense. Your other option would be to purchase a set top box and use and OTA (over the air) antenna which will allow you to receive your local broadcasts in HD.
I am sorry, however i have no heard about upgrade for this set. There is nothing available even with Sony.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 27, 2010 | Sony KV-36XBR450 36" TV
I want to buy HD ready lcd TV (resolution 1366x768 and not full HD with 1080p). IS MY OPINION CORRECT? I do not have good quality/HDsources (DVDs, BluRays), because I rather download a 700 MB or rather...
I would go with one of those tv's in your price range. Given the sources you are watching both of them should meet up to your needs and carry you through until you may need a "higher quality" tv. Either one would be a good choice for your needs.
Thanks,
Lee
Oct 23, 2010 | Televison & Video
Do you need a hd tv to use a playstation 3
Hi there, no you don't need an HD tv to use a playstation 3. You can use a standard AV cable that has 3 connectors that go to your tv, a red, white and yellow connector. This is for use on standard tv's. As long as you have these inputs into your TV then you can use it.
Obviously the advantages of HD are that graphics are much more vivid and watching blu rays in true high definition is always a bonus.
Hope this helps and thank you for using FixYa
Sep 14, 2010 | Sony Playstation 3 (PS3) Console
I bought a 1995 magnavox at pawn shop today and a attenna but tv wont let me select vhs/uhf attenna mode so the tv just snowy do you know how i can get it onto vhs/uhf mode. I believe this is a phillips...
This would be VHS only that i know of if you do not have a remote to switch to the other side is what you need its available at www.remotes.com but I beleave this is VHS only. thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 19, 2009 | Philips Magnavox MPD845
Sony Kp65sw500
You have 2 IC's in the convergence circuit and possibly a micro fuse that needs to be replaced. Consult a local TV repair shop.
Nov 23, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Sony KP-65WS500 65" Rear Projection Television Logo
67 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
