Question about Radio Shack TRC-503 CB Radio
Not able to finish transmiting.
When I transmit to another cb I only get out a word and then my voice dies out. How can I fix this problem?
  • 24 Answers
1 check and clean mic switch
2 check and repair wires in mic plug
3 if preamp mic replace battery
Posted on Jul 14, 2009
Cb not transmitting
Could just be a bad wire or the switch in the mic. It is hard to say without test equipment.
May 23, 2013 | Radio Communications
Ranger rci 2950 will not transmit
have you tried it on all bands? still won't transmit?take it to a tech so they can fix it properly.
Sep 16, 2012 | Ranger Communications RCI-6900F-25 CB...
I can hear everyone talk to me but i cant transmit to them,they can hear me key up but no voice to them.i have checked all connections and grounds,still the same.
Mic may have audio wire broken in cord at mic plug wire solder connection.
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
notice the numbers on the black plug after you pull it out of the radio.
Sep 12, 2011 | Cobra 29 LTD CB Radio
2002 Honda GL 1800 Gold Wing CB radio receives but won't transmit
Hi, Ohenry428 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
New CB Radio in 02 GL1800 Won Transmit
cb radio no transmit GL1800 Information Questions goldwingdocs com
Honda GL1800 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://goldwingchrome.com/Manuals/GL1800/Honda%20Goldwing%20GL1800%202003%20Owners%20Manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 20, 2010 | 2002 Honda GL 1800 Gold Wing
I got a cobra 29classic cb, little hours. i have
Set the squelch and knob to full counter-clockwise position. Turn the volume up to the 1/2 way point. Disconnect the external speaker plug from the jack. Disconnect any PA speaker plug from jack. Static / voices should be heard from internal speaker. If not disconnect the mic. Static / voices should be heard. If not, tune a different channel, sound should be heard. if not, look for indication of the radio stuck in transmit mode. If in transmit, there will be no sound until you can stop transmitting (hopefully while connected to a 50 ohm dummy load or suitable antenna - otherwise the final transistors may be blown). Reconnect accessories to determine problem component.
Mar 12, 2010 | Radio Communications
No audio Transmit
Try a hand mic with the set, there may be a short within the radio.If not your problem is with the audio amp in the radio itself.Repair should be about $15.00.
Aug 07, 2009 | Cobra 29 LTD CB Radio
CB Radio will receive but not transmit
Sound Like The Modulation Amp May Be Dead..
Or a Componet in The Mod. Section....You Can Pick up The Repair Manual..@ www.samswebsite.com For about $20.00...Good Luck
Feb 13, 2009 | Radio Communications
Cant hear anyone
Is the squelch off? Is there even a crackle from the speaker? Does it appear to go into transmit?
If you have a friend can listen in while you try transmitting, get him to let you know if voice can be heard, or a carrier appears (on AM). If TX OK, try sideband, if OK, look for faulty speaker/ socket/ wiring. If no audio on TX, suspect the audio amp is bad.
May 15, 2008 | Cobra 19 DX 40-Channels Base CB Radio
I can recieve but i cannot transmit
sounds like you might have a bad voltage regulator
Apr 03, 2008 | Uniden Bearcat Pro PC68LTW 40-Channels...
Radio Shack TRC-503 CB Radio Logo
105 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
