Question about Casio Telememo mODELDB360G9A Watch for Men
How do I set the right time - Casio Telememo mODELDB360G9A Watch for Men
  • 2,071 Answers
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
Dont forget to rate:
Posted on Jul 03, 2009
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
Mar 01, 2012 | Timex 1440 Nylon watch
Under the settings, limits, the limits on the max HR stop @ 100. I want to increase the setting on max hr but it stops @ 100 and then returns to 18. help [polar F4]
Go into settings.
Press the center button on the right hand side of the watch 1 time you will see settings watch time & date appear in the display.
Press the bottom button on the right side of the watch1 time to get into the TRAINING SETTINGS FUNCTION.
When you see TRAINING SETTINGS in the display press the center button on the right side of the watch once.
You are in TRAINING SETTING mode.
Press the bottm button on the right hand side of the watch 3 times until you see
ZONE LIMITS displayed.
When you see ZONE LIMITS displayed press the center button on the right side of the watch 1 time to enter into the ZONE LIMITS FUNCTION.
Now, you should see the lower end heart rate limit number blinking.
To adjust this number use the top button on the right hand side of the watch to increase this limit or lower button on the right hand side to decrese it.
When you have it set where you want it press the center button 1 time to save that setting.
Now you should see the upper limit number blinking.
Follow the same steps to set the upper heart rate limit.
When you have pressed the ceter button to set the upper limit you have completed setting the heart rates limits and the display should read: LIMITS SET!
Feb 13, 2011 | Polar F4 Heart Rate Monitor Watch
How do you set the time and date for a pokemon c watch form trend setters?
you press down on the two buttons on the right as hard as you can until it shows the time settings. It took me a long time to figure it out but i was super excited once I got to set mine xD Hope that helps!
Jan 04, 2011 | Watches
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Cannot set the analog time on the Casio 2747.
In timekeeping mode press bottom left button 6x to enter setting mode.
Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
If you hold down bottom right, it will set time at a faster speed.
Hope this helps
May 25, 2009 | Casio AW80-7AV Wrist Watch
Need instructions for setting armitron 40/6735
This should help with the 4 buttons:
Push the button Lower left and hold it for 2 seconds and you will see a number flash. This is for the alarm setting.
Push the same button again and a new screen with the time comes up and the seconds are flashing.
Push the top right button again and the minutes will be flashing.
Push the top right again and the hours will be flashing
Push the lower right one time and the time moves ahead 1 hour
Push the lower right again for the next hour and the time moves again. Do this as many times as you want to change the hours. Each time you reach 12:00 the screen will change the “A” and “P” to tell you if you are in AM or PM. Time.
You can set the minutes in the same way as you do the hours by pushing the lower right (set) button. The when done push the lower left to stop the set-up
After you set the time or the alarm, push the lower left button again to stop the set-up.
Mar 16, 2009 | Armitron Watch
I just bought a Diesel Dz 7094, and apparently setting the date and time on Diesel watches are always confusing and the manual never helps. I am having a hard time and I can't get the time set. Please help...
Press the bottom left button 3 times to enter the setting mode. The 'seconds' will begin to flash.
Press top right button to reset 'seconds'
Press the bottom right button to get to the 'minutes' setting
Now press the top right button to advance to desired 'minute'
Press bottom right button to get to the 'hour' setting
Then press the top right button to advance to desired 'hour'
Then press bottom left button to complete.
Feb 20, 2009 | Watches
How to set watch
I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
Apr 02, 2007 | Kenneth Cole RK5034 REACTION
Casio Telememo mODELDB360G9A Watch for Men Logo
26 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
