Question about Jacuzzi Bath Era BK37 959 White toilet bowl and tank
Once my tank has filled (toto toilet) the fill valve does not completely shut off. It just sort of trickles' in spurts.
  • Anonymous Mar 16, 2014
    toto cst 854 filling in spurts
  • 224 Answers
The fill valve isn't adjusted correctly. Does it have a ballcock or a newer fill valve? If it's the ballcock, there's a screw in the middle of the fill valve that you can loosen to lower the ballcock. If it's newer, you'll see a float that surrounds the fill valve. It has a small metal clip toward the bottom that you need to pinch to raise or lower the float. It also has a large plastic screw with a phillips head at the top for fine tuning.
Posted on Jul 04, 2009
My daughters TOTO toilet kepted running so she turned off the supply line before she went to bed. when she woke up the next moring and turned the water back on, now the tank won't refill. How do I know...
There could be several reasons why it won't refill. It could be the fill valve, which can be replaced with a standard fill valve located at any hardware store. The more likely reason is the stem inside the shut-off of the toilet has broken off inside the valve. This is very common when a valve is older and usually doesn't get shutoff. If this is the case, a new shut-off valve must be soldered on.
Aug 29, 2011 | Toto CST743S Drake Round Toilet
The bowl on one of our Toto Drake toilets, after a flush is complete, has very very little water in it. I recently replaced the fill valve (used a Korky fill valve). Since then I have had this problem
The small tube that comes from the Korky fill valve needs to go down the center of the tube in the tank. It should have come with a clip to clip it inside the fill tube. If the tube is running water into the tank it is just filling up the tank, not the bowl. The tank is filled with the Korky valve from the top of the tower, not the black hose. See the video below to see the black tube I'm referring to and where it should be attached.
http://www.youtube.com/watch?v=bfE8gBV0gHI&feature=player_profilepage#t=92s
Jan 10, 2011 | Toto Drake 2pc. E/F Toilet CST744S-01
How do I stop my toilet from emitting a high pitched squeal when the fill valve shuts off?
You will have to replace the fill valve...or sometimes you can try to readjust the fill level using the adjustment screw....that may help
Please rate me
Dec 04, 2010 | Toto Carrollton Toilet Tank - ST774S-01 -...
Toilet keeps running water in back tank keeps running over top of drain hole
You don't have to replace, You just need to adjust the fill valve. If you have the ball **** type just tight the top phillips screw. If you have the newer type, close the water valve under the tank and Push down a plastic ring at the bottom of the filling valve, Push down the top of the valve, lift the plastic ring to it's place and open the water valve.
Aug 01, 2010 | Toto Home
TOTO toilet Gmax fill valve
You need Korky Part # R528 available at Home Depot. Instructions are on the package and it takes just a few minutes to change it.
Dec 31, 2009 | Toto Toilets ST784S 12 Sedona Beige...
Tank fill valve sticks
Defective fill valve contact Toto for a free replacement part
Dec 07, 2009 | Toto Drake ADA Compliant Toilet with...
Changed the flapper on my toto toiet and yet still there is a hissing from the fill valve, any suggestions?
changing the flapper will not help the fill valve if it is not shutting off. It is not shutting off all the way once the water fills up, you either need to replace the seal in the fill valve or replace the fill valve. They can get grit in them or get scaled up and they stop working properly.
Oct 21, 2009 | Toto Ultramax One Piece Elongated Toilet...
Toto Drake with Gmax that oesn't completely shut off.
When you look in the bowl of the toilet, do you see the water trickling? If so then the flapper needs to be replaced.
Also, does the water run intermitentedly? As in every 2 to 5 minutes does the water kick back on to refil the tank? If yes then the answer is yet again the flapper.
Now if the water is constantly running then you can try bending the float arm (the ron that is connected to the big floating ball) down and see if that helps. If not then the next step is to replace the fill valve assembly.
Both of these together will run you about $20-$30.
Apr 29, 2009 | Toto Drake ADA Compliant Toilet with...
Toilet will not fill up
Some Toto fill valves have a plastic debris screen located at the inlet connection. Turn off the supply valve and remove the supply connection at the bottom of the tank. Use a mirror to inspect the screen for debris.
I agree w/ Smithbrother, the Fluidmaster fill valves are cheap and work well. The only thing they ever need is an occasional seal for $1.50 and 5 minutes to replace.
Mar 11, 2009 | Home
Jacuzzi Bath Era BK37 959 White toilet bowl and tank Logo
1,156 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
