A/c not blowing cold...
I would like to know if its 98 outside and 78 inside is my ac working properly or not? What is the normal indoor/outdoor difference my ac should be when it is cooling properly. It was 86 inside so I found a ac guy to come out he put his gages on it and said coil needs cleaning I said I will do that right now after you leave. I did. He hooked his guages and freon tank up. 10mins later as I watched. He said it was down about 3 lbs. He then went to his car and brought me a receipt back showing the 3 lbs and all. We shook hands and he left. I feel its still not cooling right. Was he wrong or what? Let me hear your opinion on this.
I am in the midwest its 100 degrees in the summer here alot. All this week. I cleaned my filter and the coil very well. I feel all my ac needs is CARE and the proper and right care. NEGLECT on my part is the word here as I have not had the freon checked in a few years. I clean the coil religiously though. When I feel the vent in the house it feels cool, lukewarm halfa$$ed cool if you know what I mean. I always guage a good ac guy buy the proof of the pudding after he leaves or does his work. This guy did not even ask me to know go inside and see if its cooler. The return pipe is cold and sweaty I saw it. Everything else with the 10 seer Rheem 3-2-2 1700 sq ft house ac seems to be ok. The ac drain line drips water nearby so its not clogged. I have a programmable thermostat. I set it on 71 always. And it usually does what I command. When it doesnt this is when I suspect a problem. Let me hear your thoughts on whats wrong? Oh and the guy did say the head pressure was not too bad or too high. He said he put in 3 lbs and what a deal I was getting.
  • 31 Answers
Basically for him even saying what he said, was not the right guy. Most house units with the Square footage you provided have 2-3 lbs of refrigerant yes , If he said you needed three pounds he is lying becuase you ac compressor would have burned out a long time ago and it would also short cycle too.Meaning outside unit would go on then off rapidly. In most systems a compressor has a safety where if your dangerously low it will cut off but before that you ll notice your ac blowing hot air.So that was not cool him telling you that . I'm not there to check but a real tec. would check inside and outside keep the gauges on and let you know . "even after if he did "(put 3LBS)" he should of waited about 15-20 Min's to see if it were blowing cooler.my suggestion is in the attic" You might have some infiltration of humid air coming in . Which means cut or holes in the ducts.I Hope that helped any more questions fill free to ask .
P.S. Get a real tec Who would explain better no mom and pop joints"
Kevin a Sheet Metal worker In Commercial Heating and Air Conditioning.
Posted on Jul 03, 2009
  • 999 Answers
If it was 3# low then there is a leak that needs repaired or it will go low again. A 20 deg difference is pretty good and a lot depends on hoe well the house is insulated, the sun is prevented from shining in windows and how often the building is entered or exited. The return should not sweat.
Eric
Wall AC Unit blows cold air for a little bit then blows hot air. If I turn it off for a while, it will do the same thing.
When you mansion water in the pan, do you mean the indoor coil pan or the outdoor catch "pan"? I've seen some models have a drain plug that's on the bottom of the outdoor panel or underneath. And that plug should remain installed. It uses that water to cool the copper freon tube that curves along the bottom of the outdoor section. With plug removed it can overheat. Basically it does not drain onto the ground outside, it retains its water. And the air entering side of outdoor coil is clean? May sound like repetition(forgive me). The side you see clearly is the air leaving side. The dual shaft motor has a run capacitor that may be weakening. And the outdoor air that passes thru the outdoor coil may be recirculating out then directly back in to the unit causing it to overheat. Anything blocking airflow outside? 10 mins of runtime then shouting down tells me its overheating. It may even be the electrical circuit. Loose connections can cause high amperage, low voltage issue and cause the ac load to over amp. Over amp=over heat. Hope this helps!
Jun 27, 2015 | LG LWHD1800R Wall/Window Air Conditioner
Free repair man
normally most systems can reverse the flow of refrigerant to act for heating but in e-heat mode the system is pushing heat in by its own internal fan only in normal heat mode however the system may take a while to adjust and turn on but as stated in e-heat mode it may only push heat in by its own internal fan some systems may do this
Aug 22, 2017 | Mitsubishi Heating & Cooling
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
Carrier home AC #BRC036 quit blowing cold air thru vents
Possible indoor fan motor not working or if it's blowing air just not cold air then compressor not coming on on outdoor condenser
Jun 05, 2013 | Heating & Cooling
AC is running but not cooling the house. It is a Payne unit. Changed the filter but didn't help.
Make sure the outside unit is working, both fan and compressor inside. If both of these are coming on and working, then your problem would more than likely be low/high refrigerant charge. You can also check the air flow inside and make sure it's blowing normal. Weak air flow can point to a dirty or clogged indoor coil which would have to be cleaned by taking the cover off of the coil, possibly moving flue vents out of the way, and taking the small cover off of the inside coil depending on if it's a upflow or downflow system. Hope this helps or at least points you in a better direction, good luck!
Jul 03, 2011 | Heating & Cooling
My central air conditioner is making a whistling noise in the inside unit when the compressor is running. It's not the blower because the noise stops after the outdoor unit shuts off. It's also not blowing...
If there is no cooling (meaning no cold pipes and not blowing cold air) then check the outdoor A/C for any visible/obvious issues; breakers not tripped, no debris blocking the outside unit from passing air through it, etc. If all looks ok, you can start checking some things inside of the unit if you feel comfortable doing so. Also, most indoor heaters have a higher speed/rpm for the fan when the cooling kicks on, and the heat runs on a lower speed/rpm.
Hope this helps James
Apr 05, 2011 | Heating & Cooling
Inside work blows air but not to cold but outside does not work
well it is not a power problem, because you get your power from the indoor from the outdoor in some cases . check your contactor at your outdoor it could be stuck or need replaced . if both units has there on power sorce then check your braker box
Jun 26, 2010 | Fujitsu 12RLS ThruWallWindow Air...
Our air con runs, on heat, and after a time cuts out, blows cold and makes a sort of hissing noise (but not a real hiss) and then shuts down. It then restarts after a couple of minutes. Is this normal?
Yes.Think of a heat pump as a A/C in reverce in cool indoor coil is cold&outdoor coil is hot.Naw indoor coil is hot &outdoor coil is cold&fan is pulling in cold air from outside.its going to iceup& go into defrost cycle.If your unit has a timed defrost every 30,60,or90min.(witch ever yours is set for)Defrost control board checks a sensor on cond.coil,if it is frozen unit goes into defost.You will here a swishing noise,iis the reversing of refrigerant.you will also notice the outdoor fan is not operating&at termanation of defrost fan will blow out steem.the other metod is on demand defrost.when coil freezes unit defrosts.
Mar 02, 2010 | Heating & Cooling
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Ongoing a/c issues
Wow! a 20 degree difference from inside to the outside? That is pretty amazing for a unit to operate that efficiently at such a high temperature. If the unit is cooling that well, it would also be dehumidifying. But at that high of an ambient which probably occurred between 4PM and 8PM, the peak heat of day, no a/c is going to do any better than that,(that I am aware of). Save your money, strip down to your skivvies, jump in your pool,have a cool drink, relax, and be thankful you have such a wonderful a/c.
If this advice works for you,please acknowledge your satisfaction by giving me your rating opinion,(and an invitation to your house when my a/c quits working above 96 degrees...LOL)
Dave E. (Illeagle)
Jun 11, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
231 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
