Question about Acer Aspire One AOA110-1588 Notebook
I have a an Aspire One. I cannet set up wireless. It connects to my Zyxel router but I get a message saying that there is no DSL. It is a sattelite system so there is no DSL. My other lsaptop is fine so the router is getting signal. It has Linux Lite
How do i fix connection for router zyxel wap3205
Turn your DSL/cable modem off.
Turn your ZYXEL router off.
Turn your DSL/cable modem on.
Turn your ZYXEL router on.
Restart your computer.
You should now have an Internet connection.
Mar 05, 2015 | Zyxel WAP3205 Wireless Access Point -...
I have a zyxel 600 wireless router. I just changed to a different ISP and now I cannot connect from my wireless devices. I can only connect with an ethernet cable. My wireless device detects the device and...
Get the manual from the manufacturer web site and find out how to log in to the router. You need to change the config for your new ISP. It may require user name and pass phrase before you can log in. If your last ISP was say cable, there are different options for DSL ISP's such as PPoE and the like.
What do you mean that you can;t connect from wireless devs? Can't connect to router or the ISP ?
If you reset to factory config, you need to set the router to use the same security mode and passwords as you did before the reset (or use a new passphrase with WPA2 and AES and distribute it to all workstations).
Sep 27, 2012 | Zyxel Prestige 600WH Wireless Router...
I cant hook up my d link 150 up to my toshiba sattelite laptop. i have dsl modem and i dont wanna mess it up.
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Apr 09, 2011 | D-Link Wireless N 150 Home Router 4Port...
I can't connect with other playes on my playstation network or use Wi-Fi software on Nintendo DS games with my Zyxel wireless router. How can I sort this out, I didn't have this problem with BT.
If the wireless router you have is connecting to a DSL modem you will most likely need to have your service provider bridge the DSL modem. The DSL modem acts like a router on its own so when you connect the ZyXEL router your games can't get through the connection and back. If you have a model number for the router that may help more.
Feb 27, 2011 | Computers & Internet
Internet connection keeps on dropping
Can't seem to find the manual on it but....
Most DSL/Routers have a connection setting in them with 2 settings.
1) On demand (Connects to internet as needed)
2) Always on (Stays connected to the internet)
Sounds like your DSL/Router is set to option 1
Apr 28, 2010 | Zyxel G-4100 v2 802.11b/g Wireless Access...
NBG-419N can not connect to the internet thru router?
Have you connected your Zyxel to your cable/DSL modem? Is your access problem issue with Wireless computers? The first thing you must do with a new router is to set it up, using a CAT-5 cable connected to the router. Connect it to http://192.168.1.1 and proceed through the setup items, after logging in to the router. One of the more important items, Security, must be set up by choosing your network name (SSID) and security passwords --- I prefer using the WEP-PSK[TKIP] for its simplicity. You will need the passcode you choose whemn you try to access the router wirelessly, once this is set up. Not too much access unless this is done. Use this as a guide:
http://www.zyxel.com/guidemo/NBG419N/local/networkmap.html
Nov 10, 2009 | Zyxel NBG-415N Router
I take the DSL line from my computer and put it on my ZyXEL 320w and the internet wont's connect up I cab put it back on my computer works find. and put it back to router no internet. thank you
Have you run the installation program that came with the router? Unlike a switch or wireless adapter, a router has a more complex configuration and must be set up properly. You cannot simply plug in the network cable from your DSL modem to the router and expect it to work, though it will work in some circumstances.
Sep 26, 2009 | Zyxel Prestige 320W Wireless Firewall...
Zyxel modem and wrt54g modem
You need to put the zyxel p600 into bridged mode
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
Nov 10, 2008 | Zyxel Prestige 334 Router
ZYXEL P-660HW-T1 V2 WIRELESS ROUTER MODEM WILL NOT CONNECT TO MY ISP
is your router connected to your ISP ? (does your dsl led light up ??)
if no! check your wires from phone to router!! and check your SPLITER !!! (i had the same problem, i got bad spliter !!! NEW BUT FAULTY !!!)
chears
Sep 23, 2008 | Zyxel Prestige 660HW Wireless Router...
Acer Aspire One AOA110-1588 Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
