Our Kenmore Coldspot is buzzing loudly in the freezer where the fan is. The fan is spinning, and the freezer is cold enough (as is the fridge), but it is just really loud. How do I fix this?
See if pressing on the back panal makes a difference and see if anything is putting pressure on the panel. If its vibration it is trial and error to get it positioned to quiet it down. If it is the bearing replacement is the cure. Eric
hello i have a kenmore fridge and it wont get cold neither will the freezer but, i can hear it...
(More)
hello i have a kenmore fridge and it wont get cold neither will the freezer but, i can hear it running in the freezer so is does work help!please
water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to...
(More)
water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to the bottom of frig. I SEE a drain in the back right of bottom of frig but it sits up like a knob with plugged holes.Underneath where the pan is thier are 2 tubes 1 big & 1smaller,I think this goes to the freezer cant locate please send help Thanks
The ice maker was not shut off for 2 months and freezer was frozen in all vents. When all thawed and...
(More)
The ice maker was not shut off for 2 months and freezer was frozen in all vents. When all thawed and dried we turned the refrig on again. Water formed in refrigerator and vents in refigerator started to freeze. Water was in freezer which froze in puddles and in vents again. We think the "defrost" function is not working.
