Unit freezing up
Can i let it thaw out and then turn it back on
in hopes that it will cool for awhile
will it hurt other parts of the unit if it is freezing up
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
It will not hurt the unit if you let it thaw out and then run it again. However, if you keep doing this on a regular basis, you can burn out your compressor. What are the conditions that the unit is being run under that is causing it to freeze up? Make sure that you run the unit on high cool on warm days so that it will not freeze.
Hope this helps,
Jeff
Posted on Jul 03, 2009
  • horsewoman_9
    horsewoman_9 Dec 23, 2012
    it is cold outside I set it for 65 overnight and it was frozen coils this morning..also where can I find the location of filters so I can change them
Hammering sound ptac
heat pump? possible causes: low freon. clogged / dirty coils. blower motor running?
Jan 20, 2014 | Heating & Cooling
I have two split system Conia rev. cycle air cons models CA30003. Both have "died" within a month of each other. They are just over 3 years old. The cool cycle just switches itself of and blows...
It's likely low on refrigerant and freezing...turn it off, coil thaws , cools for a short time and freezes up again. Chances are the leak or leaks are at the flares where the copper connects to the unit. Need leaks repaired and systems recharged.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 15, 2017 | Heating & Cooling
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
GE Profile "Arctica" model purchased new in 2003. Recently noticed the items in freezer partially thawed, then refreeze after awhile. No problems with the fidge section, just the freezer. Today, the...
You have a defective defrost timer or heater. One other issue could be you defrost thermostat; it might not be resetting. The most common problem is you defrost timer.
Oct 13, 2009 | Refrigerators
My Maytag MSD2456 ice-maker is leaking water and I can't tell from where to replace the part.
Is you fridge cooling and freezing properly or not? If it's not, your defrost system could be bad and the unit is frozen up not allowing the cold air to circulate, and thawing out the frozen ice, making the unit leak. Give us a call and we'll get the correct parts out to you right away to get you going again. We hope to hear back from you real soon.
Oct 09, 2009 | Refrigerators
Refrigerator stops cooling
Your defrost system is bad. When the unit freezes up, the air flow shuts down and you don't cool. When you turm it off, it thaws out and starts to work again. We have parts so give us a call if you like. Hope this helps! Ella
Aug 18, 2009 | Kenmore 63222 / 63224 Bottom Freezer...
Maytag refirigerator not freezing/cooling
Turned out to be a bad circuit board on the back of the unit which caused the refrigerator/freezer to freeze up. Replace it, thawed the refrigerator compartment, and it works fine. Cost me less than $200 including service call.
Jun 22, 2008 | Refrigerators
Jenn Air ref/freezer not freezing/cooling
Take the back out of the freezer and check and see if the refrigerator is in defrost while it is cooling if it is replace the timmer, then check and see if the fan on the underside is working if not replace the motor this will cause the problem also.
If all that is ok feel the small line under the refrigerator ( high side) and see if it is hot while it is running if not check the freon in the refrigerator.
Mar 03, 2008 | Refrigerators
Not cooling or freezing
As you've said that started it with freezing up, either the unit has a leak then the refrigerant escapes or restricted system.
In this problem you need a qualified technician to repair the leak or reprocess the system and flush out the restricted system or repair kink pipe that cause restriction.
Oct 22, 2007 | Frigidaire GLRS264ZA Side by Side...
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
