Question about Canon F-603 Calculator
Some digits disappeared
8, 9 and "point" are not appeared on the screen. What to do ?
If there is oct in the corner of the screen. Try to press shift, mode and 1.
Posted on May 28, 2008
My Gogear Vibe 8 GB appears permanently locked. A lock symbol can be seen on the screen and will not disappear with any action, including of course, sliding the lock key to the unlock position; simply...
There's a reset hole on the bottom. Push a paper clip in there. It will reset the device. Be warned though. It might also wipe everything you have stored.
Dec 17, 2010 | Philips GoGear ViBE Digital Media Player
The problem is 5.00x10^9 / 32.065 = my answer appears as 155,933,260.6 i want to set my calculator to giv my answer as 1.559x10^8 please help.
Press MODE until the setting screen showing "Fix Sci Norm" appears. Press 2 to select scientific notation, then select the number of digits you want after the decimal point.
Nov 04, 2010 | HP 10s Scientific Calculator
Nokia XpressRadio 5030 phone keypad is not working properly, problems as follows. 1) top right button does not show go to menu but shows digit 8 and disappears 2) Clicking on 2 digit number appears 23...
  • if phone has history of getting dropped to the floor or banged hard, this could cause the keypad contacts to misalign
  • try opening the case and cleaning the keypad contacts
  • best solution is have it checked by nokia service center tech support
Oct 02, 2010 | Nokia XpressRadio 5030 Cell Phone
Samsung dvd-85k unlock code
Samsung DVD-V8500K
1. The player should be powered on, the tray closed without any disc inside, the logo "DVD Video Samsung" visble on screen and the message No Disc must have already appeared.
2. Press the "Subtitle" key on the remote - "No Disc" should disappear.
3. Using the remote control, key in the code
"5, 3, 8, 1, 4"
4. A number should appear - this is the player's region number that was last programmed.
5. Press the number of the region you require, or 9 for region-free.
6. Press the "Subtitle" key on the remote - region number should disappear.
7. Press Standby on the remote control.
NOTE:
Origin of this player is Region 5 so it`s a default setting
If code "5, 3, 8, 1, 4" doesnt work try this codes:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
please rate me. its most helpful
Nov 07, 2009 | Samsung DVD-V85K DVD Player / VCR Combo
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Blank screen. Connect tto iTunes, reads it, but then disappears
Take it in to at@t nothing much the customer can do if the reset does not fix it, the backlight on it may be defective.
May 07, 2009 | Apple iPod touch Second Gen (8 GB,...
Focus error appear on screen
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
Dec 09, 2008 | Cameras
Old trinitron KV-M2121U
there mabe a DISPLAY button on your remote.
Jul 11, 2008 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Black Box on Screen
Hello...try to power off by the switch on front panel..instead of remote...then pwr up the tv and maybe it's ok...or maybe try text clock function on off..and be sure that you are in "tv" mode..so it isn't in "semitxt" mode...good luck ron
Mar 12, 2008 | iLO 2600 Television
Canon F-603 Calculator Logo
94 people viewed this question
old marine
old marine
