Question about Sony KP-61XBR300 61" Rear Projection Television
I have sound but no picture
I have the same set KP-61XBR300 and there's no picture but there is sound. Service guy came out and said its the "signal module" and he can't find a new one. Is the signal module the same as the vertical output circuit?
Can this be fixed or replaced?
    President:
  • Sony Master
  • 1,779 Answers
The Vertical may be on the deflection board. Why does't he trouble shoot the board to component level, sony's are easy.
Posted on Jul 03, 2009
How do I clean Sony KP-61XBR300
The mirror rarely needs it---access for it requires removal of entire screen unit------the lens (3) can easily be reached from rear with the back removed---you also at that time can look up to see if mirror is dirty or smudged.
Mar 25, 2012 | Sony KP-61XBR300 61" Rear Projection...
I have a Sony KP-61XBR-300 rear projection tv---- Picture went out. Is this the light bulb and if so where is located. Can I get it out myself?
This is a projection TV: it uses cathode ray tubes instead of bulbs. If you have a black screen, but still have sound, then the problem is on one of the circuit boards. Very few parts are available for this model.
Dec 05, 2010 | Sony KP-61XBR300 61" Rear Projection...
61 in. Rear Projection Television convergence will not line up and picture is bow in upper left hand corner
Hi, a common problem with Sony projection CRT TVs is the color convergence circuit, the following link shows you what the repair consists of and what kind of parts are probably involved. It will give you an idea on where to go to in case you want totry the repair yourself . the link: http://www.youtube.com/watch?v=esk4nYZKFcg
Jun 21, 2010 | Sony KP-61XBR300 61" Rear Projection...
5 blinks on front screen no picture but sound
Go to Google understanding sonys blinking codes, then Go to this website they list parts for this TV Encompass Parts Distr. 1-800-638-3328 5 Blinks say to CK Q705,732,761 and on A board CK Q218,219,220 and they say you might just try turning up screen drives on your focus/screen block it has 3 on top 3 on bottom for screen drives to tubes
Dec 03, 2009 | Sony KP-61XBR300 61" Rear Projection...
Have Covergence problem on my Sony KP-51HW40
Actually yes! If you have access to the Professional Service Manual I believe they give you an area or B&W pictures or a very poor stick drawing of the TV Cabinet that shows which boards are which.
The convergence IC's are probably STS surround sound amplifiers and are sandwidched inbetween large heat sinks. There usually are two sets - one for horizontal controls and the other for the Verticle controls.
Blessings,
A/V Media Guy
Nov 22, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a sony kp-61xbr300 as no pictures and my stand by light flashes 5 times
sound slike the light bulb has blown , take it out and see if the bulb is black or get the bulb tested. should solve the problem
Jul 06, 2009 | Sony KP-61XBR300 61" Rear Projection...
Sony KP-61XBR200 Convergence problem, when i press auto focus on the front of tv it runs its process then at the end reads (E 14G) the green color makes a bad shadow on the screen. when i cover up the...
one of the covergance chips has died
i replace both when i service a covergance
problem, they cost around 20.00 to 40.00 etch
and there easy to locate inside the tv to
get a part #
Jun 24, 2009 | Sony KP-61XBR300 61" Rear Projection...
My sony tv KP-61XBR300 no turned on and blinks 4 times red light stand by.
This code means the vertical output circuit isn't working. If the set doesn't come on at all (no picture or sound), it's usually due to power supply problems. If you get sound but no picture, it's typically because of bad solder connections or parts failure in the vertical output circuit. My suggestion would be to have a professional servicer give you a repair estimate.
Feb 19, 2009 | Sony KP-61XBR300 61" Rear Projection...
JUMPING VERTICAL WHITE LINES
UNPLUGGED TV FOR OVER NIGHT(WAS TOLD 4 HRS) STILL HAD PROBLEM. TOOK ALL CABLES OUT CABLE BOX,DVD,2 VCRS,AMP,SATELLITE, AND FM AMPLIFIER. OPENED BACK VACUUMED ALL BOARDS WITH SOFT BRUSH ,CLEANED LENSES ,MIRROW,FIRST TIME IN 10 YRS. TV LOOKS VERY SHARP!!!!!!!!!!!!!!!!! I THINK IT MAY HAVE BEEN THE FM BOSTER AMP TRANSFORMER GOING BAD CREATING INTERFEARANCE. JUST A GUSS.. COULD NOT HAVE BEEN THE DIRTY LENSES I DONT THINK THAT WOULD HAVE CAUSED INCONSIST CONSENT JUMPING LINES.ENERY THING RECONECTED (NO FM BOSTER AMP) TV LOOKS GREAT. THANKS FOR YOU GUYS GIVING ME THE CONVDENCE TO GET IN THAT PROGECT. KEEPING FINGERS CROSED.......THANKS TV IS A SONY KP-61XBR300 NOT A KP-57WS500 57 IN.
Nov 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-61XBR300 61" Rear Projection Television Logo
101 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
