SOURCE: MacBook and Mad Dog Multimedia Compatible?
I have been using my Mad Dog External CD/DVD burner for serveral years now on both Mac & PC. However, I do have intermittant issues when the computer recognizes the Mad Dog but my software does not (Toast). There is no driver for Mac as far as I know. I called Mad Dog one time and they rudely suggested that Mac does not need a driver and that I should know that. No help at all!!! I will try the suggestion for PCs to turn everything off, turn on the Mad Dog, then boot my computer and see if that works. Does anyone else use a Mac and have more solutions?????
SOURCE: need drivers for my mad dog multimedia dvd burner
Have the same dvd burner. In Windows xp pro, it finds it automatically. make sure the jumpers are set correctly. Iif you are using a different operating system, let me know.
SOURCE: Do I need software to get my comp to recognize a
Hello
Depending on which version of windows you are using, you might need to install the drivers for the device.
I know XP and older versions have a mush smaller internal driver database than windows vista or windows 7.
You don't necessarily need to install software to operate the device, just need the driver installed, then your computer will recognize the device.
Hope this can help you.
Kind regards
Andrea
SOURCE: I have a mad dog
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or Click on Start, Run, and type regedit and press Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on the plus signs (+) next to the following folders
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
