Question about Hotpoint Ultima WF860 Front Load Washer
WF860 error code
Washing machine previuosly showing H20 and stopping the cycle - attempted rinse cycle to clear through now flashing F - 08? PLease help
  • 4 more comments
  • Anonymous Nov 26, 2007
    I think so the machine is full of water now and error message is showing f -08?
  • cazzagaines Dec 02, 2007
    the machine will do a cycle but when it comes to the end it's as if it won't drain the water away then the message f-08 appears. I have tried turning it on & off but that doesn't work, I have tried resetting it by holding in on/off & start at same time this doesn't work. i know the message means the heat relay is stuck but my husband fixed this i just can't get rid of this message. Can you help?
  • Anonymous Dec 11, 2007
    H20 flashing up
  • Pinkladie Dec 11, 2007
    H2O flashing up. mode make is hotpoint wf860
  • amieedandot Jan 05, 2008
    hi
    My washing machine is beeping and stopping half way through and showing H20 error code, but it still keeps asking fr water. Is this somethng we can fix?
    Thanks
    Julie
  • Anonymous Mar 30, 2014
    whirlpool wfs1073dd washing machine showing F.08 code
    President:
  • 1,294 Answers
Click on your model numbers (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. You might find the mysterious codes there.
And dont forget to rate me on this great site.
Posted on Jan 17, 2008
Water turned off or valve faulty
Regards
Advisor
Posted on Nov 17, 2007
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
H20 error
Hello
I used to get this when i lived with my mum & dad and i can honestly say that it was the water pressure with this machine only a small drop in pressure makes the H20 error code appear you can always add additional water when it comes on so that the cycle can continue. You could find out from your water board if the drop in pressure is a leak in your area?
I hope this helps i had to persist with this problem for 18 months untill a leak around the corner was eventually found and fixed.
Regards
Wendy
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hot point f-08 fault code
F08 means that the heater relay cannot be activated.
Suggest you check heater, and or thermistor (thermostat) for a fault, replace as req'd.
Please rate my solujtion.
Thanks.
May 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Ultima WF865
i have a wf 860p hotpoint washing machine and it has come up with an error code of f 08 can you tell what this error is and how i can fix it.
many thanks
lynette
Oct 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultimasimply flashes H20.
witch one of theses are your washing machine?
lcd evo01
lcd evo02
or the V4
please let me know so i can get you the right term for the code.
Aug 14, 2008 | Hotpoint Ultima WF860 Front Load Washer
WR480 ERROR CODE H20
h20 fault code means you have a water supply problem.
check you have suficiant water pressure coming into your appliance,and also check that you have no blockages at the sump of the apliance and if plunbed to the sink check for blockages there.
f08 code means that the heater relay is stuck or open curcuit,check connections on your module and check your heater is not open curcuit,if these are ok you will require a module.
May 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
1,355 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
