Question about Husqvarna Forest & Garden 125bt Backpack Blower
I have a 130BT and doesnt start i got new plugs for it but that didnt work i took plug out and cranked it but i didnt see any spark so im thinking it must be the magneto ? and where do i find that part ? thanks
  • 34 Answers
1) Make sure the kill switch is off, or in the position to start
2) It might be a problem with the kill switch, try replacing that first.
3) Use new and clean fuel mixture
Posted on Jul 03, 2009
Worked last weekend will not start
Need more info. Is it getting gas? You can check this by squirting some fuel into the carb or spark plug hole and cranking it. If it tries to go, then it is getting gas. (Be sure to put the plug back in though). We can work from there. . .
Mar 25, 2014 | Husqvarna 130bt 130 Bt Gas Powered...
I have a suzuki vitara and fuel is available in the fuel rail but fuel not injected into cabi for burning
old post, im doing only no answer posts. my bag.
i bet its fixed and you didnt post back.
what country
what displacement engine. 1.6L 2.0L
i guess v16 means 16v or valves. or is that a v6 , 6 cylinders.
my answer, can not be any good, with out facts.
but did you use a scan tool cranking to see if you get
DTCs. if not why non, if yes, what were they.?
the coil has spark but did all spark plugs wires have spark.
using a fresh test spark plug?
the ECU cuts fuel if it THINKS spark is bad.
even if GOOD !!!!
Feb 04, 2013 | 1999 Suzuki Vitara
My mazda 626 will crank over but will not start i think someone took a fuse out
check if the car is firing by pulling an ht lead off the plugs and put another spark plug on the ht and earth the spark plug if it has spark when cranking if it is there check the fuel system if the fuel is getting to the injectors.
Jan 23, 2013 | 1998 Mazda 626
Hello, i have a husqvarna 130bt blower and it will start up fine and will idle fine but dies when squeezing throttle. I replaced gas, checked fuel lines, took muffler off and cleaned, and took carb off and...
Did you clean or replace the air filter?
Did you put too much oil into the fuel?
At idle, it it running roughly at all? If so, you may need to replace the spark plug.
Nov 03, 2017 | Garden
The car doesnt start, its not the carburator or the fuel pump. i think it might be the distibutor cap but im not sure.
Get you a spark tester at the part store and hook it to a plug wire and see if it is getting a spark there about 8$ or you could stick a screwdriver in the plug and lay it down somewhere so it dont shock you and let someone crank it over and see if there is a spark or lol you could do like me and hold the plug wire while someone cranks it for just a sec. it will shock you though.If it is firing.if no fire could be your coil to
Apr 16, 2012 | 1994 Mitsubishi Eclipse
I have a Husqvarna 130 BT will not start; spark plug gap is proper; gas mixture is proper; filter is clean and the engine is getting gas and spark; help
pull your muffler and see if it starts,if not you are looking to more serious problems like crank seals or loose flywheel causing timing to be off
May 16, 2011 | Husqvarna 295cc Back Pack Blower HVH 130BT
When Im driving my car it shuts down while im driving. when i go to start the car it just turns over and doesnt start for awhile, i took a plug off and turned it over and there is no spark but it will...
It could be as you think....but it is more likly the crank postioning sensor...the 3.3's have this issue...by the way it's located behind your harmonic balancer so balancer removal is a must
Sep 13, 2010 | 1992 Oldsmobile Cutlass Ciera
Have a 125BT and doesnt start i got new plugs for it but that didnt work i took plug out and cranked it but i didnt see any spark so im...1 Solution
Hello . To see if there's spark you have to touch the spark plug on the cylinder (metal) and pull the starter rope to see if there's spark.
If not you have a bad ignition coil that have to be replaced . The part # for the ignition coil is 531 00 96-01. Hope this help .
Aug 12, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Sporadicly the car won't start , or it takes three cranks atleast to get it to turn over..i think its not getting fuel but i need help,,anyone?!?
Most likely your fuel pump is giving out. Im not 100% sure but I think the Fuel Pump and the Fuel Filter are located inside the fuel tank. Could be a tough job to take on by yourself.
May 06, 2009 | 1992 Nissan Maxima
2002 Mitsubishi Galant wont start 2.4L
check your injectors too. maybe the problem lies there
Apr 03, 2009 | 2003 Mitsubishi Galant
Husqvarna Forest & Garden 125bt Backpack Blower Logo
577 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
