Question about Toshiba Satellite A65-S1762 Notebook
I need drivers for my toshiba laptop satellite A65-S1762
My repairer mistakenly re formatted the hard disk. I lost all sounds and drivers. help please. send the drivers to my email. I'll be glad to have them
  • 2,071 Answers
Just google the site of Toshiba.com and the they provide drivers you want .
Good luck;
Regards;
VOTIT
Dont forget to rate:
Posted on Jul 03, 2009
Forgot my password on my toshiba satellite a65
If you are talking about the user account password ..and you forgot it , now you will need to reinstall the operation system ..cause there is no way to retrieve that password..
to do that engage the recovery partition for it ..and choose complete reinstall of operation system ..If you do not have one ..(or disk ) ..use a operation system boot-able one ..Just borrow one ..or buy ..or download an image and burn one ..and reinstall your computer and will work .
let me know if you have any questions or need guidance for that too ..Please explain all facts if you do ..
Dec 29, 2011 | Toshiba Satellite A65-S1762 Notebook
Do not know the bios password on toshiba satellite a65-s1762. Cannot contact the guy I got it from since he passed away.
Hi
Remove the battery from the motherboard.
Try google to find exactly the location for this battery
Leo
Apr 17, 2011 | Toshiba Satellite A65-S1762 Notebook
I want to replace the hard drive in my toshiba satellite A65-S1762
Easy. Your HDD is located in front of the battery pack - to the side. The door is held in by one screw, and the HDD is held to a bracket by 2 screws. Any 2.5", 9.5mm height ATA IDE drives will do. Make sure you don't lose the door, bracket, and screws.
Dec 22, 2009 | Toshiba Satellite A65-S1762 Notebook
How to install additional toshiba a65 s1762 memory
Yes, you need to flip your laptop over and look for a removable compartment that requires you to unscrew a screw. Once you get the cover removed, you will see slots with either one or two memory modules installed. If one is installed, then you can add the additional memory module in the empty slot. If you have 2 already installed, then you will need to remove one and install your new module, which would only give you a total of 768 megs. Just slip the new memory in and press it down towards the motherboard and start your laptop..
May 16, 2009 | Toshiba Satellite A60 Notebook
Help me where can i download the drivers
on the manufacters website.
or try limewire or frostwire
Mar 24, 2009 | Toshiba Satellite A65-S1762 Notebook
Toshiba Satelite A65-S1762 hard drive problem
That means that the disk has a bad sector.
Try chosing the option to format the hard drive during the system installation.
If that does not work, then replace the hard drive.
Nov 16, 2008 | Toshiba Satellite A65-S1762 Notebook
Satellite a65 problem with atheros wireless driver after XP Pro SP2 installed
Perhaps what is required is to install the drivers separately and use those from the manufacturer, Toshiba. Incidentally, there are 18 versions of a Satellite A65, which one is yours pls? (Versions start from S1062...S1762).
Pls start here and select Portables, Satellite, and A65 + Version, then click on "Show Results" button.
Alternately, you may want to jumpstart and try this for the RTL8139 and/or this for the Atheros WiFi. Both are for Windows XP.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 04, 2008 | Toshiba Satellite A65-S126 Notebook
Toshiba Satellite A65-S1762 makes one long beep then two short when turned on
Sounds like video problem.
My wife has one of these and it died.
One file came up corrupt and then after I restored it the system would just drop power without warning.
Then would hang in safemode at an ATI sys file for the video.
It's on the mainboard. These also have built in RAM problems too.
You can try to remove any additional RAM you may have added in the bottom slot and try to boot.
My best advice is get a $20 best buy/staples 2.5" USB HDD enclosure and throw the HDD in there and toss the leftovers on Ebay with an explanation.
You'll get $100-150 for it to help buy yourself a new one.
Sell the LCD as one deal, the keyboard another, AC adapter another and so on. You'll get more that way.
I'd go Fujitsu. Toshiba used to be good but they went to **** to compete with HP/Compaq and sell at Walmart.
Gateway is also decent. The key is newer laptops run too hot and end up toast in a year or two.
Buy something a little less frantic in the GhZ dept. and it will last longer.
Pushing a laptop for gaming or 3D graphics is hardly it's best use. Manufacturers are too busy adding flashy selling points instead of practical features like lighter weight and longer battery life.
Aug 14, 2008 | Toshiba Satellite A65-S1762 Notebook
Open Questions:
Online Cloud Backup And Online Backup - Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
See all Toshiba Satellite A65-S1762 Notebook Questions
Toshiba Satellite A65-S1762 Notebook Logo
188 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
