Question about Dryers
Water under dryer, can feel air from under the dryer,lint traps clean
  • Craig Butler
    Craig Butler May 11, 2010
    Look behind and check to see if the vent tube is unhooked.
    Sergeant:
    Champion:
  • 235 Answers
Check the hose and air path, if clogged, dryer will not dry clothes and moisture will form in the hose.
Posted on Jul 04, 2009
Hello I have a Indesit tumble dryer that works but keeps flooding the kitchen floor? Model number IDC 85s Help!
Moister in the dryer:
This means that the moist air is not escaping correctly and that is why it is taking so long to dry your clothes - if they dry at all.
a good start at cleaning out lint blocked areas, I suggest go to the back of the dryer and take off the vent pipe or hose and check things out with a flashlight. Clean out all the lint and dust you can, even use a vacuum cleaner on it. Make sure the vent pipe is completely clear of any obstructions.Non-rigid ventshas much worse air flow than smooth piping, so you might want to upgrade tosmooth piping.
Once you have all the lint and dust cleaned out of the dryer, go to where the dryer vents outside. Again, clean the area thoroughly. There is usually a trap door that opens when the dryer air is on and closes when it is not operating. It should be completely clear of lint and opening smoothly.
Also, look into the exhaust area on the dryer carefully to see if there is a hole or gap in the dryer's internal air ducting. Without the vent pipe connected and with no clothes in the dryer, start it and let if run for a few seconds and make sure there is strong air flow from the exhaust port. You should feel it strongly on your hand.
Re-connect the vent pipe and start the dryer again. Feel all around the bottom to see if any air is blowing out from under the bottom. This would indicate there is a break or gap in the dryer's internal ducting. If you do feel air, you will need to call a service technician to see if it can be repaired. If your dryer is very old, there could be a rust hole in the duct.
In conclusion Cause ·Poor venting is a common reason why water might leak into a clothes dryer. Since the dryer works to expel moisture, it is important that the dryer's vents are properly installed so that the humidity can escape.
Effect ·If the humidity in the dryer is trapped, it will eventually turn to water. This will lead to poor drying results or longer drying times, depending on the amount of leakage.
Prevention/Solution ·Faulty dryer venting can be prevented by making sure that the humidity is directed outdoors. Also, vents should be cleaned of lint and other debris before each load so that water can readily escape. Taking these precautions can ensure that the moisture will meet dry, open air.
Read more :http://www.ehow.com/facts_7167266_would-water-dryer_.html
Nov 13, 2016 | Indesit Dryers
Why does my condensed tumble dryer leak water when drying?
Why Would Find Water in My Dryer eHow
Apr 26, 2016 | Dryers
What is causing water leakage at the end of dryer program when it goes into cool?
Mar 29, 2016 | Dryers
Miele T 659 C condenser tumble dryer not pumping the condensation out
Apr 27, 2015 | Miele Dryers
May tag Neptune dryer forming moisture inside tub
Oct 10, 2014 | Dryers
Water in basket
Aug 02, 2014 | Fisher Paykel AquaSmart WL42T26DW1 25 Top...
Hirundo washer/dryer fills with water during the dry cycle so clothes come out hot and soaked what could be the cause?
Jun 09, 2014 | Equator EZ 3612 CEE Front Load...
Dryer runs but no heat this is a gas dryer
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Whirlpool LGR3624JQ Gas Dryer
Gas dryer quit heating
Good Luck!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
Roper dryer
YOU HAVE A VENTING ISSUE WHICH CAUSE SLOW DRY STEP1 REMOVE LINT FILTER AND CLEAN WITH HOT WATER AND SOAP STEP2 MAKE SURE YUO'RE NOT CRUSHING YOUR VENT HOSE BY HAVING DRYER PUSHED TOO FAR UP AGAINST WALL STEP 3 CHECK OUTSIDE VENT TRAP IS NOT OBSTUCTED BY LINT IF THESES STEP DOESN'T WORK HAVE PROFESSIONAL CHIMNEY SWEEP INSPECT AND CLEAN VENTS
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 28, 2008 | Dryers
Dryers Logo
52 people viewed this question
Top Dryers Experts
