Question about Creda W120VW Front Load Washer
Creda W12oVW after recent wash, drum will now not turn (solid) No obvious obstruction??? belt fine, brushes still ok D
Hi m8 if the drum is solid then it could be the drum bearings which is a big job also check between the inner and outer drum to make sure there isnt nothing there
Posted on Jan 17, 2008
How to replace belt on Creda T620 CW Tumble Dryer
Remove the back panel quite a few screws, once of the belt can be seen, mind your fingers (use hook on metal coat hanger or the like) and roll the drum slowly with the hook under the belt directing it off the drum, refit is much the same as removal although special care should be taken not to nip the belt, fit to small pulley first on motor then turn drum slowly gradually rolling onto the drum mind the fingers and obviously make sure machine is off.
Nov 28, 2013 | Washing Machines
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
Creda tech came out, can he tell if machine belt is broke by just listening and turning the drum.
An experienced engineer would able to tell if belt is off, or if the main drum bearings were going, simply by spinning the drum by hand.
Feb 20, 2010 | Creda W100FW Front Load Washer
The machine is working but the drum is not
Remove the top cover and see if the belt is o/k, if it is, then you need to check the brushes in the motor, and replace if less 3 or 4mm long.
Jan 16, 2010 | Creda Washing Machines
Creda eco washing machine won't spin
It sounds like it needs new carbons fitting in the motor.
It is a fairly straightforward repair.
Remove the top cover, screws at rear, and slide top cover off towards the rear.
The motor is located at the top right right rear, you will see the drive belt.
Slacken the bolt that holds the motor, and push the motor down towards the top of the drum.
You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic`lug that holds the brushes in place, slide the brushes out of the motor.
fit new genuine Hotpoint carbons, and follow instructions on packaging. Push the leads back on to the carbon terminals.
Tighten up motor, and make sure the belt is reasonably tight.
Job done.
Test on final spin before you refit top cover.
Plz rate my solution.
Thanks.
Dec 23, 2008 | Washing Machines
Creda J1000 Front Loading Washer
Try to change the motor .....http://youtube.com/watch?v=TTSCs3kd74k
May 16, 2008 | Washing Machines
Problems with creda washing machine
try your carbon brushes and drop your sump ie the pipe that connects to the pump on the inside of the machine and goes to the bottom of the drum this is the sump that sometimes blocks or may be a weak pump but try the other 2 options first good luck dont forget to unplug
Apr 14, 2008 | Creda W120VW Front Load Washer
it is the carbon brushes in the motor. there cheap and easy to replace. go on give it a go
Dec 11, 2007 | Creda W100FW Front Load Washer
Washer won't spin
Sounds like an intermittant timer, A slipping belt if it uses one or a clutch on the drum. I looked for this make and Model and its not in my data? Sorry I cant assist more.
May 12, 2006 | Creda W120VW Front Load Washer
Creda W120VW Front Load Washer Logo
71 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
