I can not attain to dohow to booting from cd rom on hp compaq 6710b and install ubuntu
SOURCE: No sound from internal speakers on HP Compaq 6710b
http://welcome.hp.com/country/us/en/support.html
THERE YOU WILL FIND ALL YOUR DRIVER'S
SOURCE: how do you remove the power-on password for
Sadly, you must pull the laptop apart and reset the BIOS...well unless you know the password, then just remove it through BIOS.
SOURCE: Can anyone help me on how to reset the Bios
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: i have laptop hp compaq 6710b, it cannot boot
The hard disk on your laptop is a SATA, which a generic XP install disk doesn't support. You will either have to create a custom XP install disk by adding to it the required drivers as explained here
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
or you could load them to an USB stick and when prompted by the install to load external drivers from A you could reassign the A to the USB and load them from there.
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable CD-ROM. First verify that no CD is in the computer, unless you are attempting to boot from a CD.
