I have a A/C compressor (heat pump) that was working when de-installed 18 months. Unit was left ''charged'' and tubing was sealed. What are the chances this unti will still work if installed in a system and re-charged?
    Novelist:
  • 127 Answers
There should be no problem with the unit if it was removed correctly. How was the unit left charged? Not sure how they can remove the lines from the unit without losing it's charge. However, if the unit is reinstalled and properly charged, everything should work perfectly fine.
Hope this helps,
Jeff
Posted on Jul 03, 2009
How do I fix water leak from the Kenmore Coldspot side-by-side refrigerator
I would say or ask how is ur defrost timer working as this seems to indicate that ur build up of ice is more than normal hence u have more water build up that should usually be evaporating from the compressor heat and ur drain pan should not be so full. some other things to consider are below:
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
u can test the defrost timer as well
May 06, 2015 | Kenmore Refrigerators
For the last 4 months water has collected in and under produce bins where is freezes if not mopped up. I've tried pulling items away from shelf vents. Could a drain be clogged?
Apr 21, 2015 | Samsung RF217ACRS Bottom Freezer French...
Water puddling under front/door. Still cold but cant find settings info and concerned seal has gone and housing will be damaged. Less than 6 months old
Mar 25, 2015 | Refrigerators
I have a samsung refrigirator side by side with a bottom freezer door. It is leaking from the bottom of the right side of the freezer right of the free
Jul 15, 2014 | Samsung Refrigerators
What happens when serpentine belt falls off on ml320
Yes everyvthing will stop working power steering the water pump will not work hence the over heating yhe battery will not charge air con wont wirk compressor wont work there cheap enough andceasy enough to replace about £18 for belt any garage should only charge for 20 minuets work its that quick to do if you can get the diagram on which way it goes ( google images ) then you can try it yoyr self its easy to do
Apr 16, 2017 | Mercedes-Benz ML320 Cars & Trucks
What would cause hose from pump to tank on a porter cable pancake comressor get extremely hot when running
It is normal for the line going from the compressor to the tank to get very hot in all air compressors. Compressing air creates allot of heat. It will get hot enough to cause burns if touched.
Nov 18, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I recently changed the alternador belt on a 2001 chevy metro lsi, afterwards whenever i start the car , there is this rattling noise and when i opened the hood to check , to the left of the alternador...
Water Pump REMOVAL & INSTALLATION Metro
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Air cleaner
    • A/C compressor suction pipe bracket, if equipped
    • Loosen the water pump pulley bolts. Do not remove them at this time
    • Right side lower splash shield
    • A/C compressor drive belt
    • Lower alternator cover plate
    • Water pump/alternator drive belt
    • Crankshaft pulley
    • Water pump pulley
    • Timing belt
    • Dipstick tube
    • Upper alternator bracket from the water pump
    • Water pump and discard the gasket
    To install: Fig. 1: To ensure a tight seal, be sure gasket surfaces are properly prepared - Metro 7922z704.gif
  4. Clean the gasket mating surfaces thoroughly.
  5. Install or connect the following:
    • Water pump with new gasket. Torque the bolts to 115 inch lbs. (13 Nm).
    • New rubber seals
    • Upper alternator adjusting bracket
    • Oil dipstick tube
    • Timing belt
    • Water pump and crankshaft pulleys. Leave the water pump pulley bolts hand-tight
    • Alternator drive belt
    • Lower alternator cover plate. Torque the bolts to 89 inch lbs. (10 Nm).
    • A/C compressor drive belt, if equipped
    • Right side lower splash shield.
    • Torque the water pump pulley bolts to 18 ft. lbs. (24 Nm).
  6. Adjust the water pump drive belt tension and torque the alternator adjustment bolt to 17 ft. lbs. (23 Nm).
  7. Install or connect the following:
    • Air cleaner
  8. Refill the cooling system.
  9. Start the engine and check for leaks, repair if necessary.
Prizm 1.6L ENGINE
  2. Drain the engine coolant.
    • Negative battery cable and properly support the engine
    • Right side engine mount and support
    • Upper and middle timing belt covers
  4. If equipped with power steering remove the following components:
    • Front transmission mount
    • Radiator fan motor
    • Coolant reservoir
    • Upper radiator hose
  5. Remove or disconnect the following:
    • Crankshaft Position (CKP) sensor electrical connector from the dipstick tube
    • Dipstick tube
    • Engine Coolant Temperature (ECT) sending unit
    • Coolant inlet pipe
    • Water pump and discard the O-ring Fig. 2: Remove the coolant inlet pipe from the block, then the pump - Prizm 7922z705.gif
    To install:
  6. Install or connect the following:
    • New O-ring and Water pump. Torque the bolts to 10 ft. lbs. (14 Nm).
    • Coolant hose to the pump
    • Coolant inlet pipe. Torque the fastener to 11 ft. lbs. (15 Nm).
    • Dipstick tube. Torque the bolt to 89 inch lbs. (10 Nm).
    • ECT sending unit to the dipstick tube
    • Engine wire harness. Torque the bolt to 89 inch lbs. (10 Nm).
    • Radiator fan. Torque the bolts to 52 inch lbs. (6 Nm).
    • Coolant reservoir
    • Front transmission mount. Torque the bolt to 47 ft. lbs. (64 Nm).
    • Upper and middle timing belt covers. Torque the bolts to 62 inch lbs. (7 Nm).
    • Right side transmission mount and insulator. Torque the bolt to 47 ft. lbs. (64 Nm).
  7. Fill the cooling system.
  8. Start the vehicle and check for leaks, repair if necessary.
1.8L ENGINE
    • Drive belt
    To install:
  4. Install or connect the following:
    • New O-ring and water pump. Torque the bolts to 8 ft. lbs. (11 Nm).
    • Drive belt
  5. Fill the cooling system.
  6. Start the vehicle and check for leaks, repair if necessary.
Jan 02, 2011 | Chevrolet Metro Cars & Trucks
How do i take off the old water pump on 1996 geo metro 4 cyl?
Removal & Installation
  1. Disconnect the negative battery cable.
  3. Remove the air cleaner.
  4. Remove the suction pipe bracket for the A/C compressor, if equipped.
  5. Loosen but do not remove the 4 water pump pulley bolts.
  6. Raise and safely support the vehicle.
  7. Remove the lower splash shield.
  8. Remove the A/C compressor drive belt, if equipped.
  9. Remove the alternator drive belt.
  10. Remove the crankshaft and water pump pulleys.
  11. Remove the timing belt.
  12. Remove the oil level dipstick and tube.
  13. Remove the alternator adjusting bracket from the water pump.
  14. Remove the water pump rubber seals.
  15. Remove the water pump mounting bolts and nuts and remove the water pump from the engine.
Water pump mounting location
  1. Clean the gasket mating surfaces thoroughly.
  2. Check the water pump by hand for smooth operation. If the pump does not operate smoothly or is noisy, replace it.
  3. Install the pump using a new gasket. Tighten the bolts to 115 inch lbs. (13 Nm).
  4. Install new rubber seals.
  5. Install the upper alternator adjusting bracket and tighten the bolt to 17 ft. lbs. (23 Nm).
  6. Install the oil level dipstick and tube.
  7. Install the timing belt.
  8. Install the water pump and crankshaft pulleys. Leave the water pump pulley bolts hand-tight.
  9. Install the alternator drive belt.
  10. Install the lower alternator cover plate and tighten the bolts to 89 inch lbs. (10 Nm).
  11. Install the A/C compressor drive belt, if equipped.
  12. Install the lower splash shield and lower the vehicle.
  13. Tighten the water pump pulley mounting bolts to 18 ft. lbs. (24 Nm).
  14. Adjust the water pump drive belt tension and tighten the alternator adjustment bolt to 17 ft. lbs. (23 Nm).
  15. Install the suction pipe bracket for the A/C compressor, if equipped.
  16. Install the air cleaner.
  17. Refill the cooling system.
  18. Connect the negative battery cable.
  19. Start the engine and check for leaks.
83667f6.gif Water pump assembly showing rubber seal location
    CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  3. Remove the air cleaner assembly.
  4. Loosen but do not remove the four coolant pump pulley bolts.
  5. Raise and support the vehicle safely.
  6. Remove the lower splash shield.
  7. Remove the air conditioner compressor drive belt.
  8. Remove the lower alternator cover plate bolts, loosen the alternator adjusting bolt, and remove the drive belt.
  9. Remove the crankshaft pulley.
  10. Remove the coolant pump pulley.
  12. Remove the oil level dipstick and guide tube.
  15. Remove the water pump mounting bolts and nuts. Remove the water pump from the vehicle.
To install:
  3. Install the pump using a new gasket. Tighten bolts to 115 inch lbs. (13 Nm).
  5. Install the upper alternator adjusting bracket and tighten bolt to 17 ft. lbs. (23 Nm).
  6. Install the oil level dipstick and guide tube.
  8. Install the water pump pulley and leave the bolts hand tight.
  9. Install the crankshaft pulley.
  10. Install the water pump/alternator drive belt.
  11. Install the lower alternator cover plate and tighten bolts to 89 inch lbs. (10 Nm).
  12. Install the air conditioner compressor drive belt by releasing the tensioner pulley and installing belt.
  13. Install the lower splash shield and lower vehicle.
  14. Tighten water pump pulley mounting bolts to 18 ft. lbs. (24 Nm).
  15. Adjust the water pump drive belt tension and tighten alternator adjustment bolt to 17 ft. lbs. (23 Nm).
  16. Install the air cleaner assembly.
  19. Start the engine and allow it to reach operating temperature. Check for leaks and refill cooling system as necessary.
Mar 06, 2010 | 1996 Geo Metro
Refridgerator/B-Freezer not cooling
System refrigerant must be recovered prior to any work done on replacing any part of the sealed system, Recovery unit required at about $750.00. After recovery the compressor lines must be disconnected by heating to a temperature above 1385°F, Torch required , cost about $350. The compressor electrical wires must be disconnected. The motor mounts must be disconnected by removing clips or bolts. The compressor can then be removed. The new compressor can now be installed and the mounts connected. The piping can be cleaned fluxed and re-soldered using a high temperature alloy such as #45 silver solder. #15 if the stub tubes of the compressor are copper. A new system filter/dryer must be installed. Electrical wires must be connected to the new compressor. A deep vacuum must be pulled on the system to remove and air , moisture and non-condensible gases for the internal system. Then you can charge the system by weight to the exact amount shown on the system name plate and the proper tyep of refrigerant.
So the answer is yes it is difficult and requires a good technician to be done properly.
If the unit is out of warranty it is not recommended that the compressor be replaced at you expense.
Jun 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
