When you set the machine on a normal wash, or any wash for that matter, the machine times out to the last minute,and stays there, however the machine does not wash or spin
  • 4 Answers
As set out above i am experiencing the same thing with mine.
Posted on Jul 03, 2009
How do I get the door to open when still locked after normal cycle stopped with 1 minute left?
Try putting it through another cycle and see if it is still going to stay locked. That would seem like a timer problem. The door should only be locked normally, as I see it, when there is power applied to the locking solenoid so it should not remain locked with no power. You might call a maytag dealer and ask a sales or service person about this also.
Sep 08, 2014 | Maytag Washing Machines
Pr5 message is displayed
the electronic program is corrupt. just use an alternative setting.
Mar 10, 2014 | IFB Washing Machines
When the water drain, the machine just make noise and the drum stay still for more than 10 minutes based on the timer countdown. Then I pause and start. Noise & no movement. However this does not happen at...
Angie This happened to my washing machine. What I did was I tried some programs , empty, spin, short washing. After I had tried quite a few programs it started working correctly again. It is worth trying. Kolbrun
Sep 19, 2013 | Electrolux Washing Machines
I have a WTW6600SW1 Whirlpool washer that stays unbalanced even when empty. How do I fix it?
A memo was issued by service matters to remove the counterweight on the base of the machine and add springs to stabilize lateral movement.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 21, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I need the reset codes for my dishwasher. It gets stuck in demo mode at times. That's what the repair man said who came last time. My dishwasher is the Whirl Pool Quiet Partner I, Model Number...
Hi, this is the reset code: Push/Press 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
Wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later it will start working....
Jun 11, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Good afternoon. Here is my problem : Approximately one year ago between (November and December) we started using this White Kenmore Elite Oasis washing machine [ Mod. 110. 28032701. Ser. 0470359 Type...
LF is a long fill code. So it is taking a long time for the washer to get water. Is this happening on the cold or hot water temp selection? Does the water seem to be filling OK? If not check your hoses for clogs or kinks. Then check the water valve screens for clogs. If no clogs are detected and the water is running in the machine slowly and out of the hose (when disconnected from the machine) regularly then you have a water valve problem.
Dec 15, 2010 | Kenmore Washing Machines
My dishwasher is seeming to stay on the wash cycle. How long is a normal wash cycle?
Dishwashers today use a lot less water and energy to do this they filter the water like crazy this makes the wash times go way up, the motor used today uses only a little power so a long cycle does not cost much.
They average wash time for a new machine is 90 - 120 minutes. Some high efficiency units can run 4 hours per cycle.
Apr 24, 2010 | Kenmore Dishwashers
I have a calypso washer it seems to be stuck on the heavy cycle no matter what i dothe display says 53 mins it wont do anyhting wont start if i hit the button wont let me choose another cycle like quick...
I just ran into a similar problem. Ours was stuck on Normal with 42 min. Started beeping every couple minutes last night after bad rain storm. Couldn't get it to stop. it would turn off if I hit stop and a couple minutes kater (like 2min) it would come on by itself. Left it unplugged overnight until about 6:00pm. Plugged it back in and it wnt right back to the normal mode after about 2min. HOWEVER, I keft it sit with the lid open and it beeped every couple minutes for a while then suddenly stopped. I checjked it and it is off, hasn't come back on. I haven't tried to run a load through it yet, so I don't know if it is fixed or not..
Oct 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer front loader model LHW0050PQ
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
Nov 15, 2007 | Malber WD1000 Front Load Washer/Dryer
The machine doesn't work
Is your load within capacity. See that it is. Press and hold 'spin' & 'dry' for 5 or 6 seconds to unlock controls. Try the machine on a normal cycle once, see if it works.
Apr 14, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
